y'all can have your shares and $800k investments, all i need is an income that can support me and help fund the wanky-est of VIP accessories. you could have a multi-million dollar car, but it wont have a slot for medium or large maccas chips or croc-skin benches to rest your sunnies.
http://www.garson.co.jp/english/interior_i/e_potato_h.html
Swarovski-approved colour diamonds encrusted into just about everything. car rubbish bins, seat covers, dash mats, gear knobs, licence plate surrounds, valve caps. and just like Junction Produce, to become a distributor for their products you need to "buy" into the company first (Junction Produce is like somewhere between $5k-15kUSD).
1849109365_569a41f236_z.jpg?zz=1
  • Like 1
On 7/9/2016 at 9:47 AM, UNR33L said:
yer cops over there are f**ked, killed over 500 people this year alone..
And how many of these are people who have pulled weapons on cops? probably >90%...
So, is it the cops fault they needed to defend themselves to stay alive and make it home? Or is it the 'victims' fault for pulling a weapon, or doing something stupid (like suddenly reaching into their pocket or waistband) that made it look like they were pulling a weapon?
If they want to stop getting shot by police, they need to stop carrying weapons and pulling them out all the time because someone looked the wrong way at them...
  • Like 1
That^
American cops might have shot 500 people but they also lost something like 30 of their own this year already.
Cultural issue but they will never get rid of guns. Too many people with a "just try and take my guns off me" attitude towards life. The irony being that the guns are supposed to be protecting them; instead inciting civil wars because people don't know how to use/carry them safely.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
