I told you what you should do if you were gonna mod a 34 sedan or Stagea, Moh....
(the answer is: Don't)
Or if you must, buy someone else's project, the bigger the project the bigger the savings.
15 minutes ago, Birds said:
Yeah it's been awesome, am very lucky. I still think the share is ridiculously undervalued given the company prospects and asset potential, which is why I haven't sold out. Just gotta think of the profits as reinvestment instead of taking it out.
88e is doing a good job of flying under the investment radar, which will send it into orbit if/when we cop good news and mainstream media starts reporting it. That's pretty much how it ten bagged last time.
I'm still in the red, bought in too late :P
37 minutes ago, admS15 said:
Sell it, buy autech 260 rs
i got this for cheap, like, your asking price is 6 times what i paid for this greg haha.
43 minutes ago, Leroy Peterson said:
Has it got ecu? How much can you get ecu? Injectors/exhaust/intercooler/hi-flow then be done. Don't touch it after that.
nah, just tein coil overs
its a series 2 so, neo motor.
is really neat so just thinking nistune, injectors, highflow and keep the stock side mount for maximum surprise.
  • Like 1
I'm gonna disagree with this.
I've rebuilt every aspect of the pulsar minus the gearbox (stay tuned for that one).
A few reasons why it was a bad choice:
Seller was asking a lot and very firm on price and extra parts.
70% of the professional work done was super poor. It worked and was hidden, but not good enough to anything beyond occasional road duties.
Hindsight: build from the ground up and learn to do it properly in the process. Or better yet, start with another's project that has some goodies THEN tear it down and remove all the shit.
True, its probably best you can either a) Vouch for the car/owner and b) Absolutely know what you are looking at.
It can obviously burn you badly, but if you know what you are doing its the way forward.
However usually done through having been burned in the past, but hey 99% of people here on SAU will know what they are doing regarding other people's projects and know when to spot a bad apple
Clearly you haven't read any of the OP posts in the modifications area, or been anywhere near the facebook group.
OK...I'll pay that.. It is pretty clear a lot of the Facebook group queries certainly consult FB before google..
It's so true but makes zero sense. Maybe the day people can't be bothered responding on fb will be the day people stop asking before Google.
1 hour ago, joeyjoejoejuniorshabadoo said:
I don't know if this has been addressed before... But why the f**k does Mohsen now put every post as a spoiler alert?
because im here to spoil your lives
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
