1 hour ago, Leroy Peterson said:
i'm selling a pair of 275/35/18 Yokohama advans (non-AD08) with minimal wear, so if anyone is hardcore hit me up. will do m8's r8's for VWL.
If only they were 19s..
Martin would of rubbed on the inside, I'm running 9.5 +30 on all 4 fine, the utes have massive rear clearance too people chuck 11s on the back of the utes! I'd suggest getting 19s though, 18s look too small on big ass falcon
Edited by UNR33L
this was a 255 tyre on a 17 X 9 +36 and rubbed on the front strut.
(grabbed one of the old rims off the S14 when I got a flat..no bingo.
but I've buckled one of my current rums and deciding if I should fix or get new ones
25 minutes ago, UNR33L said:
Dezz brah, you in our out with 88e? Now is the time to make the call :P
Ballsey dropping out of it now I reckon
market halted in response to ASX inquiry. starting to get some Deja vu...........
london price friday night was pretty flat, not sure how today will do.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
