25 minutes ago, Leroy Peterson said:
market cap of $2mil was changed to $250mil last minute. I dont get that. anyway, my measly $500 will wait till Oct.
my thoughts exactly, no f**ks given
I'd like to point out that E85 Scotty recently sold his yellow, stroked out evo, adding to the list of former evo owners.
However, the buyer was old mate Sunkist/Aaron...who previously owned a white one. I wonder how long it lasts in his hands...
Mate I give it a month before that flamin mongrel sells it
  • Like 2
If I buy the supra I'd have to allow 2 years for Barry to build the bottom end
No, you would become a 2j fanboi that believes they can take 1000hp totally stock
Lol 2Js are better than RBs no doubt about that
but... 1000hp from a stock bottom end sure...
might only last a few thousand Ks though :)
He likes Toyotas more, it would prolly progress faster than an RB. I notice the Toyota blocks are always the most complete looking in the engine room haha
  • Like 1
What's taking so long on yours now Birds?
Shouldn't be much in the way of it besides Barry's daily work now. Machinist took ages with my block but that's done now, so onto the assembly and conversion. I've been told before end of the year so here's hoping.
Ahh really? I thought it was a complete engine ready to bolt in.. I'm guessing he's just giving it a freshen up with new bearings and what not?
Yep sort of. It was complete (head separated from engine, but intact nonetheless). Barry offered to pull apart the block, check and reassemble...I thought it would be stupid not to while it's out and it's a second hand engine. We found the head comp was way too high from being over machined and some of the machining on the block was rough, so he sent it off to get tidied up. It's added a lot of time to the project but very glad he found that shit before it gave me troubles in the car...
  • Like 1
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
