Matt Borci or anyone else
Been out of the loop lately. Looking for a new fully synthetic e85 compatible oil to replace my Castrol Edge 10w60
Figure i dont need the 60w now that i have an oil cooler and no longer track it.
Was thinking 10w40? Which Castrol Edge dont do
On 9/20/2016 at 7:22 PM, Birds said:
Did they have an option where we can pay $500 and you get arrested
i wish
On 9/21/2016 at 0:55 AM, Odium said:
Quick VWL fundraiser to cover costs....
yuuuussss
Penrite ten tenths racing 10w40
  • Like 1
Oil cooler doesn't change anything. Castrol Edge 10w60 all day every day.
  • Like 2
3 hours ago, Leroy Peterson said:
lol does this mean the wheels dont clear the brakes?
gonna finally bite the bullet and get simmons?
http://simmonswheels.com.au/wheeldetails.php?wheel=22-inch-simmons-om
yeh they were way off, 8mm spacer still wouldn't fit - I knew it going into it though
3 hours ago, Jonnoo said:
I got thrown off by the lack of price tag
like anyone here could afford em, too much lost on 88e
fair enough. it was more so on the street oil takes ages to warm up even with a thermostat and hardly goes above 75 to 80 on normal driving
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
