10 minutes ago, Kinkstaah said:
Can anyone actually recommend a suspension place that won't go "Oh it's a sedan, I see your money and your questions are beneath me and please stop lowering the property value of my amazing shop"?
as this happens quite a lot
Shockworks do setups for Falcons and Commodores, so no reason to reject your vehicle short of it bringing a meteorite down onto their workshop
www.shockworks.com.au
Give him a call
I was happy to go there, but I'm really looking for a place that will repair/replace suspension geometry as opposed to just fixing the issue by selling coilovers. Seems like the actual springs and struts are the least of my worries now.
That said I always thought the tail being a bit slidey was due to this torque spike as per here:
http://www.sau.com.au/forums/uploads/monthly_2016_09/57eb13251b249_DynoGTX3582RPower.thumb.jpg.3d244a1923896738611d6b0dd20f2308.jpg.pagespeed.ce.mloANxsVLK.jpg
Speaking of suspension, when I got my brakes put on the guy noticed my front right coilover shock has gone and leaked it's oil out. Got quote $220 for replacement part from pedders.. considering just buying a new front right complete coilover and wacking it in instead but not sure it's worth while even doing any of it - car feels alright and not like it sees the track.
Greg if car seems aight just leave it :P
Leeroy - maybe some Emotion CR ultimates, aint too shabby.
Edited by UNR33L
32 minutes ago, blah_blah said:
How are you not dead yet?
I'm yet to go to Sandown in the dry with HICAS still enabled with busted rear wheel bearings and HICAS tie rod ends apparently.
So it should be any day now.
yeah... i prefer some of the other work wheels, but certainly got heaps of caliper clearance.
any pics fitted to a falcon?
Read the website you twit
Just read the website.
It makes sense and I should have read the website and utilize their business.
Thank you for your informative post. I am appropriately admonished for not reading.
Well we got there in the end...
4 hours ago, Kinkstaah said:
To be fair if I do go the whole hog and replace shocks and springs I would consider Shockworks or MCA really as the only two options to choose from. I may get away with a new set of coils, hicas lock bars and toe arms to suit, and two rear wheel bearings.
Still somewhat shit when my initial complaint to get checked out was "hm, the front seems to be pretty happy to hit bump stops and isn't low"..
You tell them you have a single issue.. They say yes you do and heres 5 other problems. Now you're disappointed in THEM that they've pointed out more safety issues than you realised.
Legit no wonder why they don't want to take the job on. You don't book a haircut for 4.30pm and then when you get there change it to a cut, colour and 10 other things you can do at a salon.
What I'm saying is you told them you had an easy job for them to make a profit on and instead served up a turd and asked them to polish it.
Nope, I actually asked them to do a checkup and they did.
They found faults in their eyes, and reported them to me in great detail which I am appreciative for and I shall get a 2nd opinion on.
Because some of the things mentioned are so severe that they necessitate a 2nd opinion.
They have found things I've never noticed/didn't know where there and things like "your two rear bearings are utterly f**ked" seems like it would show up when you shake the entire car by the wheel and notice no movement.
I'm well aware that they may not have had time/resources to take on such a job and that's fair enough when you're working in an industry like that.
It isn't somewhat shit of them, it is just somewhat shit in life to go for something simple and find out a lot else is on the plate that you didn't know about and now you do.
I asked them for a check and I got a check. What I did not do was ask for a check then demand they fix it all in the time allotted for a check, dude. I'm not that kind of customer, or human being really.
Fair enough then.. maybe I have misinterpreted how you wrote your first couple of posts on the issue.
Buy some Superstreets / Street Advance. Better than Shockworks, better than BC and cheaper than both.
16 minutes ago, blah_blah said:
If other people are keen pat and i and some other wastelander are going to cars n coffee tomorrow at sandown. will just meet at my house im 2mins from sandown
i was thinking about going.... what time y'all heading in?
i might be helping someone with a stereo install tomorrow
PS calder drags rescheduled due to weather
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
