19 minutes ago, joeyjoejoejuniorshabadoo said:
So you were running about the same power as my car which would have 0% traction loss with 8kg rears and less suspension work...
Yep, but your power came in way later. I have 4KG rears with helper springs, a Nismo 1.5way diff, running -1deg camber and AD08R's which were up to temp and running 30psi hot.
Not saying it's the best setup in the world, but it's not like it's a slammed 15KG rear springed 2 way on stretched 195 nankangs that cost $4 each :P
Yeh the other thing that I gotta keep in mind is the falcons are sensitive to diameter, like if the fronts have 650mm diameter and the rears have say 600mm (an example) traction control light just goes nuts thinking its spinning all the time, which is annoying because the 265/30 is cheaper than the 275/30s but the diameter is slightly smaller and don't want to have those annoying ass problems.
So I stick to tyre sizes I know look good and work
Edited by UNR33L
  • Like 1
1 hour ago, UNR33L said:
True, I mean I just copied pasted the emails but yeah. Finding sticky tyres in 19s with the right sized sidewalls, a lot of makes just make them big sidewalls which I don't really want (like a 245 / 40 as oppose to a 245 / 35) Invos / RS3 / NT05s / AD08s much harder to find them in the sizes I want, and if I do sometimes the prices are just stupidly high compared to the 'thick side wall' of the same tyre. Anyway seems st george are probably my best bet
Go with the more common one. remember sidewall is a % of the width too, not a direct measurement
was your microphone broken Mr Trump?
1 minute ago, JAS-25T said:
who does lifts from the airport to city for less than the skybus?
isnt it like $18 a trip? i dont bring the gloria out for less than $50 unless im already in the area.
13 minutes ago, HEKT1K said:
Lack of PT from the airport is balls
I'd be happy to give up the most liveable city title for a year or two to get this done
yet neither liberal or labor will do it....
we need Kennett back... Kennett would have done it if he had time
What was your top speed out of Curiousity?
1.29 aint a bad time in a sedan auto
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
