well its taken a month, a bunch of headaches and more questions than answers, but my telstra cable is finally setup.
comparison:
Is it worth the trouble and an extra $10 a month? if it can maintain over 10mb/s 24/7 then yes.
The provided modem/router is pretty useless... wont tell you speeds or chart usage or even let you change login username (wtf, stuck on admin forever). Now just to figure out if I can use my Fritzbox for Wifi only...
  • Like 1
On 10/7/2016 at 8:32 AM, Leroy Peterson said:
I wonder what the IT section at Telstra is like....
Would it be filled with ex-public servants who just dont give a fark and do nothing all day.
Or would it be generally younger IT personnel who just dont give a fark and do nothing all day.
Or would it be a small team of extremely over-worked individuals that are constantly putting out fires and trying to resolve the countless issues that arise?
What Department?
comparison:
This image is showing 13Mbps, not 13MBps...
8 Megabit = 1 MegaByte
The plan you are on is a 30Mbps plan and you're achieving 13Mbps.
Either there is a problem with your connection or there's congestion in your area at the time of testing... Try again later and see if it hits the full speed.
This is what a 30Mbps plan should look like:
100Mbps plan should cap out at about 115... Either way you're not likely to see the difference in the two speeds unless you download a lot of big files (not talking about torrents), or need additional upload speed (the 100Mbps plan caps out at ~2.4Mbps up instead of ~1.2)
So is this shit? Never been impressed by our internet speeds and we have had this Optus Cable for the last 6+ years.
Steam displays speeds in MBps... 2.9Mbps x 8 = 23.2Mbps = edging closer towards your 35'ish maximum.
Try http://speedof.me/ and see what result that spits out... I find its a bit more accurate, and doesn't require flash either.
Also when testing, make sure nothing else on your network is download anything... and don't be on wireless if you want an accurate result.
Blow me pat
  • Like 1
Thank f**k someone knows the difference in abbreviations
Felt like I was taking crazy pills
I mean what the shit is this Patrick
4 hours ago, Rekin said:
12.5mb/s is 100mbps - that's a good speed. Can't get faster on cable.
Getting stooged on your upload maybe? Mine is 1.15mbps on ADSL2, but only 12.5mbps download
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
