Congestion just means they don't have enough backhaul to provide the service... Modem means there's a fault and they can't provide the promised service.
Either way, you're not getting what you paid for, but it's Telstra... They used to have the monopoly on comms infrastructure... but with NBN ramping up thats going to change soon. So good luck getting them to spend money to maintain their soon to be unprofitable network.
  • Like 1
Yup and with the abandonment of Optus cable infrastructure, you will need to wait for Nbn's fibre to the curb.
http://www.gizmodo.com.au/2016/09/nbn-will-roll-fibre-to-the-curb-to-700000-homes/
However I believe Telstra cable infrastructure will be upgraded to Nbn's hybrid fibre coax
For those that don't have me on FB but want to know what Supermoto is all about made a video of the track day over the weekend :)
Basically a dirt bike with slicks or road tyres on a dirt / road track, so riding on the dirt is sketchy af and can't use any front brake.
Edited by UNR33L
Had to get puncture sorted out today, the guys that swapped tyres onto my new rims pulled out a screw that I had on a tyre, it filled it up and left it saying she'll be right, nek day take it back to get plugged.. zzz
I would of thought if I could tell something was wrong, they would be able to tell but eh.
Edited by UNR33L
88e going back down again eh
things are a bit shakey in the states, with the election and wall street scares. Couple that with british pound still on the fall, oil price retrace because some people think this OPEC agreement will achieve nothing. The other thing (which may or may not be true) is the upcoming announcement potential dates are a bit vague so people looking to jump on the bandwagon may not wanna tie up their money for potentially weeks. 88e team mentioned theyre more interested in stabilising share price than playing a game of hype and peaks/troughs.
and then theres hotcopper... where everyone is circle-jerking each other and putting themselves through financial hardship to fund "the greatest investment opportunity in all existence" while being firm that all patience pays off (regardless of how long that takes).
Yeah aussie internet really sucks dick.
Even in the middle of buttf**k nowhere when I was in Vietnam on guest wifi was getting 50mbps up / 50mbps down
#straya
Except that Australia is 23x bigger than Vietnam with 93million people vs our 20mill.
My 24 month NBN contract is about to run out. All this talk of shitty internet just reminded me I have to shop around.
All internet providers use the same cabling/infrastructure if you are in a NBN zone.
Think of isps as owning a lane on a freeway. Although a multi-lane freeway has been built, if dodo has only paid for 1-lane it will get congested at peak-hour. Whilst Telstra could have 3 lanes to itself.
So internet in Melbourne or Sydney has to be shit? I get that in the outback but doesnt need to be shit in the capitals, NBN just slow af to come
Take that argument up with your isp. Technology exists for gigabit speeds & the backhaul is built for it. Supply & demand - and the isp's have lost a chunk of their profit since they don't own the network anymore
41 minutes ago, HEKT1K said:
If you aren't a massive nerd it's fine bruz
Get over it
I'm talking more about business for productivity not home net
True, best most of our customers have is like a telstra 50/50 or 100/100 which cost em an arm and a leg
Edited by UNR33L
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
