1 hour ago, dezz said:
Given my engine is 320kw stock, the 325 kit becomes the 375 kit I believe... Seem to be big losses though, 375kw resulting in like 280rwkw on their hub dyno... Maybe I've been out of the game too long but I don't remember skylines etc having that much drive train loss..
Holden's don't have huge drivetrain loss, it's just that their power figures are bullshit to begin with... They've always been that way
I heard a car flipped at sandown wrx track day on the weekend. Possibly turn 1. Maybe tried to steer through the kitty litter.
I'll need to check natsoft to see what times that white 33GTR was doing...
Yeah holdens always been more about a 'real' power figure which doesn't equate to much 'rwkw' compared to ford who list their number as almost 'rwkw' number. Not hating on Holdens, I actually like both. Holden have better interior and features, and update the nicer things more often, ford have better gearbox / engines IMO
There's 2 ways to go about an SS, big dirty cam and exhaust, keep it N/A for just over 300rwkw (ish)? or just bite the bullet and slap a charger on it from the get go for 400rwkw (ish)
Edited by UNR33L
17 minutes ago, dezz said:
Getting to sensible in my old age... Jetski once a year track bike and $500 Saturday nights not withstanding
Sell Jetski and get a supercharger, at least you use the car.
Keep bike cos it aint worth much, then track it when you can be stuffed.
15 minutes ago, dezz said:
And how could I forget my terrible share portfolio
You and me both, the lesson here is, never try.
Wow any extra details? links?
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
