24 minutes ago, emts said:
Mainly as I'm a country red neck.
Fair enough, if I got one would have to be 2nd car.. couldn't 'downgrade' the current car for one :\ 2 car regos can fek right off though
Edited by UNR33L
Anyone know anyone who's got a RB25/Neo block laying around? As I am now onto my 4th and sleeves don't seem to readily exist because "What exactly would you sleeve it with that's stronger?"
(yes I shall turn down the powers)
http://www.ebay.com.au/itm/Ford-Coyote-Miami-5ltr-Supercharged-FPV-GT-Engine-740HP-/122190780243?hash=item1c73235753:g:c3EAAOSw-CpYBsAa
:D
Nah but serious, I'll ask my brother what he is doing with his.. his 33 has been sitting on the side of the house for about 3 years
Edited by UNR33L
  • Like 1
[emoji32]
Time for billet block
1 hour ago, Leroy Peterson said:
Tis the GTR way
Then once thats done, you just spend your days trawling for Nismo "bargains"
Omg Nismo key for $500
[emoji32]
i got one but its probably no good
12 hours ago, joeyjoejoejuniorshabadoo said:
Built RB'S are the single biggest waste of time, effort and cash in the car scene.
i wouldnt expect a GTST owner to know.
WOW I FEEL LIKE I NEED TO HAVE A SHOWER AFTER SAYING THAT
  • Like 2
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
