11 minutes ago, Birds said:
Whilst I still think 88E will slump again in the short term, the current news is great for long term holders
Reading between the lines, you don't bid on another 150,000 acres of land if there's nothing special under there...
Have you got Dave Wall on Facebook yet
  • Like 1
43 minutes ago, Mohsen said:
boys,
have any of you built with Henleys?
also has anyone looked into digging out the garage for more storage?
Porter Davis
Respect The Dream
1 hour ago, Mohsen said:
boys,
When my parents built they put a pit in the garage for servicing cars etc, works pretty well and covered up when not using by planks of wood in the grooves.
Its all concreted and proper done, no issues in 27 years
  • Like 1
boys,
Mate did - no complaints
Digging is entirely dependent on the site - hit rock and it'll cost ya
yeah had one in the shed growing up so good when I got into playing with cars power down there and all.
Going the hoist option myself however.
http://www.abc.net.au/news/2016-12-15/federal-court-orders-pirate-bay-blocked-in-australia/8116912
Lol okay.
Really Australia? gonna make people waste a minute of their time using a vpn? sigh. That's if it's an IP block. DNS blocking would be lols. Just use another DNS server..  why fight it?
Edited by UNR33L
Quote
But Mr Burke was confident this approach would not be popular in Australia.
"The experience overseas is not many people use VPNs because they cost money as well," he said.
"(A torrent website user would) still face the issue of dealing with viruses, scams and a pretty terrible, terrible neighbourhood so I think that should factor, but I think also when we explain to people that it's not a victimless crime, that other people lose their jobs, I think that will have an impact.
Especially in a country like Australia, where we're pretty damn vehemently opposed to anyone we consider to be a tall poppy.
Most people care literally less than nothing about the people in that industry.
Funny how he tries to make VPNs sound expensive, hell all you would need is a free one just to get onto the site then download your .torrent file, turn off VPN, back on your AUSSIE connection downloading the torrent because they can't / aren't blocking all the trackers and seeders.
Like I said if it's a DNS block, LOL will take 2 secs to get around it by changing your routers DNS server to something like Googles 8.8.8.8 instead of Telstras etc.
I'll let you all know the fix once they do it for Telstra, if they even do..
Lol okay.
images.jpeg.0f01c9c5b41a667c18e65b7b9957
20 hours ago, Birds said:
Porter Davis
Respect ThE Dream
ill give them a sus
early days anyway; pit would be the last resort, and even then i might as well turn it into a secret cave.
where i can mohsen freely.
true true, guess well have to wait and see hey.
i dont have the room to go 3 car garage so my other option is to dig down and try have one of those short hoists squeezed in there.
14 minutes ago, Leroy Peterson said:
Do majority of adults even torrent anymore? So many people have netflix. Only thing it doesnt cover is HBO (right?)
There's a fair few shows they don't cover and they don't always show them straight away as they're released.
Also niche things like the grand tour, fast n loud car shows I watch. Hell I don't even thing they have the big bang theory on it in Australia?
3 minutes ago, emts said:
do netflix and such let you cache data on a tablet?
the small amount I torrent is for watching crap on flights.
sad thing is it's all stuff I could get on my foxtel go but no data on planes.
Dunno about netflix but you can with youtube on a mobile device.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
