18 hours ago, Odium said:
Got your entry to Broadford Greg. Will see you up there. You going to come and say Hi this time or not?
17 hours ago, Birds said:
He said hi to me last time, but I think that was only because I walked past him as he was fixing his car...
There's a lot of mental processing reserved for exploding cars that don't drive right and being a complete noob driver you know!
Finally got a friend's old beamer going and he also signed up for SAU. This is the guy that was fixing my car at Sandown while I was blabbing to Birds. His rationale for joining SAU was "Well unlike the BMW club they are at the track, and also I've fixed enough Skylines to be an honorary member even if they don't know it yet"
2 hours ago, Down_Shift said:
Lost 3-4kg in the past 3weeks... not sure if fat or body mass.
Thought I would be gaining whilst jobless.
that just means you're eating too much at work, maybe you're a heavy snacker?
or maybe you walking around more now?
Edited by UNR33L
So drove the S14 back home to the country today.
I really forgot just how bad the highway done/pot hole wrecking the back was.
that said the few sweeping bends went though made me remember why I did what I did.
I see a trailer in my not too distant future.  and many more track days
54 minutes ago, emts said:
is that one of the chinese ones with the phone home with full data on it?
I'm not sure what you mean.... but yeah, Chinese phones taking over yo. My HTC is over 2 years old now and app updates have just made it a slug for running most things. Reverted back to factory default for what apps I could and they run much better. Don't think its worth spending much on a phone if constant updates render everything redundant in a short span, a la Apple.
Considered the Nokia 3310, and it looks like the good ol' days of functionality but really need SOME basic internet stuff.
https://www.theregister.co.uk/2016/11/15/android_phoning_home_to_china/
TLDR
apparently a bunch of Chinese phone companies have firmware that monitors all traffic on the device and sends home
meant to be for mainland only but "accidentally" put on international ones as well.
Meh, if they want to monitor my sending of memes and organising car or family meets, then they're more than welcome to. The socialist party council can add me on Facebook for all I care. Need those instagrum followers
  • Like 1
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
