*sigh*.... I think I'm going to buy an XR6 Turbo :/ Bang for buck on an FG MkII is just too good to pass up compared to everything else in my criteria.
Post-2010, newer the better
Over 200kw
Under $30k
No Out of Warranty Euros
It's either Commodore or Falcon, and the towing capacity on the falcon wins out. Pity the interior is a bit basic.
*sigh*.... I think I'm going to buy an XR6 Turbo [emoji32] Bang for buck on an FG MkII is just too good to pass up compared to everything else in my criteria.
Over 200kw
Under $30k
With a few small mods it's good for an easy 350kw, let alone 200kw
XR6T has the same interior if you get the leather option (like mine) just make sure you get one with "premium sound" and "colour screen", reverse camera even better (like mine)
Leather, colour screen, premium sound (subwoofer), reverse camera are the options you want. Then the interior won't seem as cheap.
If you get a 2012 or newer it'll be mark 2 with a touch screen and different headlights + front bar , and they're all colour so slightly better oh and they have bluetooth music streaming, unlike mark 1 which has ipod connection + aux. (still bluetooth for phone CALLS though)
the xr6t engine makes around 250rwkw ish stock anyways, tune it with injectors, new dump + cat, intake and you see some pretty good gains
oh and yeh, they tow like you've got nothing on the back.. awesome towing cars. #fordsalesrep
Edited by UNR33L
i hope you wrote that with a VB in your hand....
  • Like 1
I wish.. cup of tea
Nothing like chopping cars with a trailer on the back, dat extra grip. Although scared I'm gonna rip the back of my car off sometimes so don't launch it, just on rolls
Edited by UNR33L
Pretty sure the G6E T has the same engine and gearbox, but no LSD and softer suspension?
2300kg is an impressive tow weight, compared to 1600 for most commodores unless you get a wagon and calais
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
