I got nothing but praise for Internodes customer service and billing/sales. Now that i have an NBN box installed i would switch back to them in a heartbeat
Though guy at work is trying to convince me MyRepublic's $60 high speed NBn unlimited plan is the way to go
Search whirlpool for CVC for each isp. That's what you are paying for now as it's all running on the same infrastructure.
Car washing stuff. OMG got onto a telstra tech that know's what he's talking about :O
Tier 1 is offshore. Tier 2/3 are onshore to deal with any fall-outs/exceptions/complaints
In the case of billing disputes or customer complaints where you are ready to walk most banks/isp/telco's have a Business Saves team which are responsible for convincing potential leavers to stay. They usually have more authority to provide compensation/escalations. To get transferred through to them however requires you to trigger some keywords/questions to validate your intention to move.
2 hours ago, Odium said:
Pretty sure the G6E T has the same engine and gearbox, but no LSD and softer suspension?
2300kg is an impressive tow weight, compared to 1600 for most commodores unless you get a wagon and calais
Pretty much yeah just the diff.
I THINK even the suspension is the same.
The 6 speed auto is a great gearbox, and as you said has good towing weight.
Don't forget they all use 5x114.3 too so you can wack on some spare JDM wheels yo. if you ever need/want to.
How much you looking to spend? I'll keep my eye on the club fg group..
Edited by UNR33L
Chasing a Mk2 for ~$25-28... Specd up interior is a requirement now that I've looked into the differences you mentioned.
I'm alright with some mild mods as long as they're subtle and it comes with a RWC.
Yeh that'll get you a nice mark2, the touch screen is a nice touch, they have the projector style head lights too.
Must get leather though, as all the door trims etc look wayyy better.
Mark2 look alright in white, those are stock wheels too
Edited by UNR33L
  • Like 1
16 hours ago, Birds said:
Wicked keep it up
Your old pants must be huge on you
thanks bruh.
down to a size 36... used to be a 40-42, ive kept them though. chuck them on when im working on the car lol.
i couldnt even fit into slim cuts and down to an L work shirt...
belly and titty fats being fair stubborn though.
Do falcons without upgraded sound system still have room to install an aftermarket sub? Plenty of gear to fit falcons floating around. Im sure itd be cheaper than factory options, probably no difference if secondhand.
Got done speeding in the domain tunnel when it was at 60km/h. Cameras adjust with speed, eh? well there ya go. Gonna try for the good behavior letter and hope it lets me off. Haven't had an offense in around 3 years I think.
You broke the speed limit, why do you think you should get off
one of my employees got done for a high level drink driving offence in sydney on new years, plead guilty and lost his license for 12 months.
believing it only affects sydney, continued driving and got picked up in a set up, then got caught again the next day.
hes still driving... and reckons 12 months is too harsh.
well, wait till court day mate... i reckon hes gonna cop an extra year for the two unlicensed driving offenses as well.
I think the standard sound system doesn't have tweeter or sub grills in the pillars / parcel shelf, and also no amp.
Mines premium has the 2 front 2 back, sub in parcel shelf, amp, and 2 tweeters up front. I'm sure you could fit your own stuff but imo the premium sound is fine if you find the right car. Took me a while to find a GS fully optioned already at a showroom in black, finally found one and bought it
Cannot stress enough how bad the cloth interior vs leather looks though.
Simon, try find a cheap GS 5.0l? :P nothing good on carsales at the moment though
Edited by UNR33L
standard system sucks massivly, I've repalced them all with 6inch co axials in front and 6x9 at rear, much improved (not much space for a sub in the cabin...)
also added the aux connection as the radio in the BA has shocking reception, thus the external antenna in the FG
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
