I guess most amateur drift cars break shit so often they don't get to drift regularly. But if it's been drifted it's probably pretty f**ked anyway.
Can't win. Lesson: drifting is bad mk.
There's the arugment that a car is tracked often must have been setup well/is reliable/has been looked after and used "as it should be" etc.
Vs a 25 year old car with 2,000kms on it.
well im working away from home for the next 4 months. Better hand over some cars to some workshops to get stuff done.
need eastside Auto transmission (or decent regular mechanic) to do some auto box work on the gloria. fix minor leak, replace small gasket, swap oil and see if it fixes sluggish shifts. greg?
Edit: booked in at Knox Automatics.
Knox is good for east side, they just don't like the 34 because.... I don't know? For servicing and general stuff I'm sure the'll do it just fine. Whether it will fix things is a different story.
Asking for a custom transmission that holds 500rwkw different story again!
I got mine done by DTM Autos out Westside, as in Geelong. Would also recommend for general auto stuff but yeah.. Geelong is not within what most people consider "acceptable travel".
I didn't, mine is a PCS2000 controller/ECU.
Probably has similar features. Though a plug and play solution would be great, though my brain is curious to know how exactly it's plugged and played into an ECU when the pins controlling the auto on a GTT are ... plugged into the Engine ECU...
Mine is wired in, but the truth is that there's only ~10 or so wires that needed to actually be wired in.
Also, WTS.
Gonna need a car trailer with upgraded leaf springs.
Transporting a dead hooker on an open car trailer is a poor decision. You need to use an enclosed one, he didn't mention that in his request and that could come back to bite him hard.
2 minutes ago, TiTAN said:
What time is a good time to question it?
trick question...never ever question it, unless you want a headache
Just chuck a car cover over it...or if it was a dude chuck a sail boat cover over.
  • Like 1
THIS is along the lines of what I was thinking...
http://www.dmhperformance.com/photogallery.htm
f**k varex. Thats how you do an exhaust valve. and you can add piping to it if you want
That's the kind of thing I told you to get pages back.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
