35 minutes ago, Kinkstaah said:
Anyone know a decent auto elec that is mobile in Vic?
Not necessarily an "after hours cash only" style job, need a professional that can un-f**k a clusterf**k.
You and Pat
  • Like 1
I dont know any mobile auto elecs, no. Will be taking pulsar to a motorsport wiring place to do stuff from scratch, seems like lots of auto elecs dont like f**king around with others peoples messes.
Also lol @ comparable deductions to other sparkies.
Claiming unnecessary performance mods for your car on tax is immoral. Like claiming dog food for security purposes.
Good luck to you, but youll probably get found out eventually and get reamed like Gregs R34 at Racepace.
2 hours ago, dezz said:
If I'm gonna do it, should probably get it done before eofy.
Other thing to consider is warranty... Walkinshaw / harrop etc offer warranty, at a cost, haven't really looked into how it affects the manufacturer warranty if at all... But my mate recommended dynomotive or dpm, sounds like they offer more and better quality for less than walkinshaw etc...
Does their warranty cover your engine or just their component failing? Be surprised if any engine modification offered liability insurance against total engine failure given so many indirect variables can cause it.
Centrifugal chargers also have the tendency for an engine to not feel 'boosted' at all, a positive displacement charger you mostly feel down low, turbos give a big turbo kick we're all familar with
Centrifugal chargers just feel like a larger N/A engine, their power on a dyno is almost a completely straight 45 degree line. So you do get instant boost, but max boost is always at max engine RPM.
After installing turbos, my next car is going to be a supercharger setup.
Heat management > ALL.
A RB with a 300KW centrifugal charger instead of a Turbo would probably drive like a similarily powerful V8 N/A (like a LS1-2)
Except way less problems with heat, lines, plumbing, etc.
If I was adding F/I to a car which didn't ordinarily have F/I (like a S2000?) a centrifugal charger suddenly becomes really very viable.
I think there's a handful of people who have done supercharged RB's.... I don't think any of them recommended it.
Hell even the supercharged SR20 people usually go turbo afterwards. Same with F20 Honda motors
Engines too small.. by the time you add a charger you're making it struggle even more, say hello to your RB15 (1.5L, that's the joke)
Is there any point spending money on a EJ257? from my research looks like minimal gains (intake exhaust tune ~35whp?) Asking for... a friend.
Edited by UNR33L
Pls just stop
  • Like 1
Changing the forced induction method on a vehicle that came factory with FI is very silly
Superchargers have a constant lag of their own that is just negated by the power gains when they start making a little boost. You'll notice it on a smaller engine and fuel economy will suffer even if not giving it stick
If you want that supercharger whine just do a gilmer drive or smash your air con compressor with a hammer until it whines
E85
Should be first stop for any decent FI power gains. Improve performance absolutely everywhere!
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
