35 minutes ago, Kinkstaah said:
Anyone know a decent auto elec that is mobile in Vic?
Not necessarily an "after hours cash only" style job, need a professional that can un-f**k a clusterf**k.
You and Pat
  • Like 1
I dont know any mobile auto elecs, no. Will be taking pulsar to a motorsport wiring place to do stuff from scratch, seems like lots of auto elecs dont like f**king around with others peoples messes.
Also lol @ comparable deductions to other sparkies.
Claiming unnecessary performance mods for your car on tax is immoral. Like claiming dog food for security purposes.
Good luck to you, but youll probably get found out eventually and get reamed like Gregs R34 at Racepace.
2 hours ago, dezz said:
If I'm gonna do it, should probably get it done before eofy.
Other thing to consider is warranty... Walkinshaw / harrop etc offer warranty, at a cost, haven't really looked into how it affects the manufacturer warranty if at all... But my mate recommended dynomotive or dpm, sounds like they offer more and better quality for less than walkinshaw etc...
Does their warranty cover your engine or just their component failing? Be surprised if any engine modification offered liability insurance against total engine failure given so many indirect variables can cause it.
Centrifugal chargers also have the tendency for an engine to not feel 'boosted' at all, a positive displacement charger you mostly feel down low, turbos give a big turbo kick we're all familar with
Centrifugal chargers just feel like a larger N/A engine, their power on a dyno is almost a completely straight 45 degree line. So you do get instant boost, but max boost is always at max engine RPM.
After installing turbos, my next car is going to be a supercharger setup.
Heat management > ALL.
A RB with a 300KW centrifugal charger instead of a Turbo would probably drive like a similarily powerful V8 N/A (like a LS1-2)
Except way less problems with heat, lines, plumbing, etc.
If I was adding F/I to a car which didn't ordinarily have F/I (like a S2000?) a centrifugal charger suddenly becomes really very viable.
I think there's a handful of people who have done supercharged RB's.... I don't think any of them recommended it.
Hell even the supercharged SR20 people usually go turbo afterwards. Same with F20 Honda motors
Engines too small.. by the time you add a charger you're making it struggle even more, say hello to your RB15 (1.5L, that's the joke)
Is there any point spending money on a EJ257? from my research looks like minimal gains (intake exhaust tune ~35whp?) Asking for... a friend.
Edited by UNR33L
Pls just stop
  • Like 1
Changing the forced induction method on a vehicle that came factory with FI is very silly
Superchargers have a constant lag of their own that is just negated by the power gains when they start making a little boost. You'll notice it on a smaller engine and fuel economy will suffer even if not giving it stick
If you want that supercharger whine just do a gilmer drive or smash your air con compressor with a hammer until it whines
E85
Should be first stop for any decent FI power gains. Improve performance absolutely everywhere!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
