if anyone holding TV2 from last year wanted to get out, i think now is the time. Even if the share price improves over the next 6 months, doesnt sound like the company is too organised. I think this was like a desperation announcement to attempt to keep things afloat and restore faith in holders.
Meanwhile 88E... give it a few weeks.
18 minutes ago, dezz said:
Share price almost doubled since that post..
I still think TV2 is too risky.
It was only a fortnight ago the company had no income and $700,000 in monthly expenses, with impending voluntary administration. Now all of a sudden they have income from money they were owed and now contracts in the pipeline. Brazil is the next target... what happened to the stuff in Africa not that long ago?
but why are we all here talking about broken laptops and motorbikes?
if we had just pulled our heads in, we could have been part of the million-dollars-by-30 club run by our old mate.
If only we had moved to western suburbs and spoke chinese...
  • Like 1
Mandarin is now the second most spoken language in Australia
Asia has also taken over Europe for migration to Australia
And there was another one...20% of those from Asia immigrated in the last 5 years, I think
So now the statistics have finally caught up with what we all knew years ago lol
1 hour ago, joeyjoejoejuniorshabadoo said:
I actually didn't know that
Now ya know
nigga
  • Like 1
Why wouldn't they? If there's money to be made on brokerage fees etc.
Just seems funny requiring a bank to buy currency that does away with banks.
Pretty sure it's all direct deposit, unless buying off someone specifically.
In the 3 minutes of research I did on bitcoin, you need to set up a wallet to trade it... Think most are free or ~$5
My share portfolio is up around 8k this week... Only matters tomorrow though, don't like seeing red for the weekend
  • Like 1
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
