Car question:
Whats an equivalent spark plug for BCPR7ES or something that is a decent copper plug that can suit up to 400rwkw (including 400kw).
And can I buy them off a shelf.
If so, where. All info seems to have disappeared about 2012 re: Spark plugs and none of this stuff is on shelves anymore and I want to buy them on the weekend, in Melbourne.
Car question:
Bkr7e but try R and E auto parts on centre rd springvale. Next door to repco. They usually have stock of bcpr7es. If you get stuck I have a set of 6 that I've only used for 50km. Replaced them chasing a misfire that turned out to be something else.
  • Like 1
I have some iridium 8's that were $75 a plug and were scheduled to last a lifetime. They haven't given me an issue but I do get misfires at 20psi (380+kw).
So I thought to stop using amazing super plugs, and wanted a basic plug that is known to work, as its cheaper to try that first than replace Splitfires (which are now getting on in age, almost 10 years).
I got a misfire at idle that went away, and I'd like to have plugs in my hand ready to go should they be needed instead of looking ages later when I have a car running on 2cyl or some shit.
Car question:
I was using bcpr7es plugs at 394rwkw.
So I would just get those.
Guess I'm headed to RE Autoparts then!
They seem harder to find than most, these plugs, figured people would have found some other alternative on a shelf. Good to know the BKR7E is usable if in a pinch
I get my BKR8's from Springvale Autobarn. or Bursons. i cant rememeber. I got a box of em.
24 minutes ago, admS15 said:
Everyone stocks 6 heat range but not many have 7. Greg also give bursons a call if r and e has no stock. So are you planning a track day this weekend ?
Nope, just had misfires at 20psi and a random one at idle today so wanted to have something on standby.
$80 plugs you use "forever" I don't trust to actually last forever :P
Nothing lasts forever, especially plugs. I got sucked into iridium's once, never again on a modified car. Copper for life. Like birds, I buy them in bulk. Last couple of times through spares box, where about $4 each and free delivery on overs over $50.
How the f**k did you research plugs on SAU and then buy iridiums expecting them to last?
There has to be at least a hundred threads telling you not to bother and just use BCPR7ES
Iridiums aren't a total scam per se, they do last for many times longer than normal plugs do...but the assumption made by the marketing claim is that they aren't going into a high performance car. A daily driver can use iridiums and will probably not notice a degradation after 50,000km etc. because performance decreases aren't as obvious nor are the plugs performing in an extreme environment. Iridiums wear like copper plugs do, but will retain say 70-80% of their performance after 10,000km, unlike the latter. This is useless in a high performance environment where you want plugs to be delivering 95%+ and as Iridiums can't do that any better than copper, better off saving your money.
I didn't research here. I spoke to Trent @ Chequered while my car was literally being tuned, and asked him what plugs to recommend for my setup at the time, taking in account my timing, ease of change, desire to not have it blow out and for it to last forever.
What he recommended did just that, I never had spark issues until I took a lot of timing away, and took a lot of boost away.
So I was asking on a more common setup, which is closer to what I have now, and the BCPR7ES work really quite fine, no misfires at all and I'm really happy with that, and really not that hard to change or check. The old plugs really were going strong but not suited to what I am doing now (they were also too cold a range, looking at them out of the car)
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
