Car question:
Whats an equivalent spark plug for BCPR7ES or something that is a decent copper plug that can suit up to 400rwkw (including 400kw).
And can I buy them off a shelf.
If so, where. All info seems to have disappeared about 2012 re: Spark plugs and none of this stuff is on shelves anymore and I want to buy them on the weekend, in Melbourne.
Car question:
Bkr7e but try R and E auto parts on centre rd springvale. Next door to repco. They usually have stock of bcpr7es. If you get stuck I have a set of 6 that I've only used for 50km. Replaced them chasing a misfire that turned out to be something else.
  • Like 1
I have some iridium 8's that were $75 a plug and were scheduled to last a lifetime. They haven't given me an issue but I do get misfires at 20psi (380+kw).
So I thought to stop using amazing super plugs, and wanted a basic plug that is known to work, as its cheaper to try that first than replace Splitfires (which are now getting on in age, almost 10 years).
I got a misfire at idle that went away, and I'd like to have plugs in my hand ready to go should they be needed instead of looking ages later when I have a car running on 2cyl or some shit.
Car question:
I was using bcpr7es plugs at 394rwkw.
So I would just get those.
Guess I'm headed to RE Autoparts then!
They seem harder to find than most, these plugs, figured people would have found some other alternative on a shelf. Good to know the BKR7E is usable if in a pinch
I get my BKR8's from Springvale Autobarn. or Bursons. i cant rememeber. I got a box of em.
24 minutes ago, admS15 said:
Everyone stocks 6 heat range but not many have 7. Greg also give bursons a call if r and e has no stock. So are you planning a track day this weekend ?
Nope, just had misfires at 20psi and a random one at idle today so wanted to have something on standby.
$80 plugs you use "forever" I don't trust to actually last forever :P
Nothing lasts forever, especially plugs. I got sucked into iridium's once, never again on a modified car. Copper for life. Like birds, I buy them in bulk. Last couple of times through spares box, where about $4 each and free delivery on overs over $50.
How the f**k did you research plugs on SAU and then buy iridiums expecting them to last?
There has to be at least a hundred threads telling you not to bother and just use BCPR7ES
Iridiums aren't a total scam per se, they do last for many times longer than normal plugs do...but the assumption made by the marketing claim is that they aren't going into a high performance car. A daily driver can use iridiums and will probably not notice a degradation after 50,000km etc. because performance decreases aren't as obvious nor are the plugs performing in an extreme environment. Iridiums wear like copper plugs do, but will retain say 70-80% of their performance after 10,000km, unlike the latter. This is useless in a high performance environment where you want plugs to be delivering 95%+ and as Iridiums can't do that any better than copper, better off saving your money.
I didn't research here. I spoke to Trent @ Chequered while my car was literally being tuned, and asked him what plugs to recommend for my setup at the time, taking in account my timing, ease of change, desire to not have it blow out and for it to last forever.
What he recommended did just that, I never had spark issues until I took a lot of timing away, and took a lot of boost away.
So I was asking on a more common setup, which is closer to what I have now, and the BCPR7ES work really quite fine, no misfires at all and I'm really happy with that, and really not that hard to change or check. The old plugs really were going strong but not suited to what I am doing now (they were also too cold a range, looking at them out of the car)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
