But see, when you buy a 34GTR it becomes a part of you.
On your instagram page, you need to state that you have a 34GTR, because the images don't always get the message across. To some people, $75k is a small price for a personality and attention.
  • Like 2
Saved a few of those 40-50k R33 GTRs on carsales to see if they move.. they're still there
Anyone actually know of anyone that's BUYING them for these prices? :P
Edited by UNR33L
Anyone actually know of anyone that's BUYING them for these prices? [emoji14]
I did... I paid almost 60k for mine. In fact it was a little more by the time shipping and roadworthy were included.
I don't regret it as I couldn't land a decent LM Limited for the same price from Japan.
You see that R32 tuner car on speed hunters last week? $130kUSD and it's got China cast-looking wheels and a 90's Japanese turbo.
As much as I love the japs, there are good tuning shops, then there are overpriced and dated tuners.
13 hours ago, Rekin said:
R32 GTR's were going for $18k
Skyline life was good back then.
Just shelled out $600 for a new gtr front bar & it's missing the $400 lip.
Dat gtr tax
If I recall, Alvin picked up his 32R for 12-13k when they were at their lowest
  • Like 1
All relative methinks...it used to be that high 20s were the permanent carsales residents...then it was low 30s...
Even if it's only the cheaper ones moving, the cheapest are now no longer <30k listed
Hard to tell where the investment in one would top out. USA market availability did small wonders for R32s, but will the hype/buzz wait for 33s and 34s? As the cars become rarer, parts more expensive / harder to find, could be an eventual decline in interest
35 minutes ago, UNR33L said:
Toby, if my last employer isn't returning my calls for a group certificate request can I just use my last pay slip? Has gross YTD and tax YTD on it should be fine?
Has it pre-filled? They should have reported by now
Thought it was a relatively large / reputable place where you used to work
Not sure, I usually have a tax guy that does it.
Nah was only 3 people where I was, was made redundant once the work ran out.
Legally need to give it to employees by 14 July
They dont need to lodge it with the ATO till 31 Oct so may not be on prefill.
Yes you can use YTD payslip unless your Payroll officer does something wrong
  • Like 1
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
