29 minutes ago, Leroy Peterson said:
all about dat short term. people with over a hundred grand dont wanna sit and wait for something that could possibly fail. rip n run. i dont blame em.
But they're long term holders...
NSW flights all f**ked. Gonna miss my connecting flight in Sydney, every other flight booked except $1200 business class seats at 9:30pm.
No point trying to contact Qantas when every other person in the airport is on the phone trying to get through
*sigh*
59 minutes ago, admS15 said:
Id want a C63 and a happy ending for that price, lol.
There will be a gay benz driver somewhere who could help you out with that for free...
$160 car hire.
$360 one-way airport drop off interstate
28c/km after 200kms.
Ill worry about reimbursement later, just glad to be home. Gave someone from site in a similar situation a lift so was good to have someone to talk to.
What did I get from it over other options? Bus/train didn't leave till this evening, arrive in Melb at 7am. Business class Qantas was $1200 and didn't leave till 9:30pm. First economy flight out of Sydney was 6am next day. So I basically got home the quickest method possible.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
