Just now, Birds said:
Would you have posted if it didn't rise :P
Every stock I've posted has gone up significantly. I wouldn't recommend a stock if I hadn't done my research first.
Cant say I'd recommend 88e though ;) actually it looks like it's found support at ~1.7 might be good for a trade from here...
Same here...but ultimately there's always risk involved which is why no one jumps at it just cause someone says it. Wasn't until people started seeing me profit from 88E that I was able to get anyone onboard for the ride. FWIW when I first tipped it on here they were about 1.5 cents and went on to 8 cents within a few months. Whether people capitalised on that or not is another thing!
I agree 88E has found something of a floor until the next major news. You could just about guarantee a win from buying now and selling at the inevitable ramp up leading into well re-open...if you're patient enough to wait 5 months that is.
  • Like 1
28 minutes ago, Daz said:
I'll be recommending another stock soon (just building a position first :)
I'll follow if I have cash at the time - test your theory ;)
1 hour ago, Leroy Peterson said:
I was browsing stocks and went through 6 pages of VWL and couldn't find it :(
I've been watching MIN with interest lately...
MIN looks like a solid co, probably wait for a pull back :)
I'm trying to find the next company that will go from 1c to 1$ :)
I've been wanting to look into uranium, SLX has done well in the past when uranium price goes up.
Have MUS and BYE on my watch list but wasn't keen to jump on board... Then boom.
PLS has done some wonderful things. I forgot who tipped it to me but I've had it on watchlist and didn't invest. Now scaling back but has seen incremental consistent increases for last couple months.
Shock works and BC will rebuild their own shocks... Not sure about others.
Also, good luck getting discount rent for lack of services. My heaters been broken since August (urgent appliance needs to be fixed within 9 days) and all I get out of it is the ability to break the lease...
MIN looks like a solid co, probably wait for a pull back [emoji4]
I'm trying to find the next company that will go from 1c to 1$ [emoji4]
Please let me know when you find it. I've got substantial losses from an oil company that I need to recoup
  • Like 1
1 hour ago, Kinkstaah said:
Bilstein will rebuild them, but they're in Sydney and the turnaround time is ~3 weeks during which I have no car..
Therein lies my problem!
Quadrant in Berwick, they're Bilstein dealer IIRC.
Which reminds me, I should ask them if they have softer springs for my PSS9, worse case, Heasmans.
They were, and they are now closed/rebranded as "H&R". I went to them when they were still quadrant and they said that the place was for sale at the time.
Bilstein Australia actually said they have no local dealers. (via FB).
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
