Short of sending them to Heasmans, there's a mob in thommo that I wouldn't recommend that was a Bilstien dealer back then and he tried to tell me BC coilovers are "great" - truth is they're garbage especially roads up in Norfies.
So yeah, Heasmans or Fulcrum (dunno if they're still selling Bilsteins now, I asked them earlier this year and they do).
I don't even know what shocks I have, Only that they are pretty good. I wrote down B6, so I figure when I had them off the car in the past... I wrote this down then...
Bilstein Aus said the leak is a bit normal as they tend to weep when used normally, as long as it's not leaving trails or actual drops of oil on the shock itself it's not blown. They also said a lot of shops diagnose them as blown when in reality they are working as expected.
Kind of nice of them to not just take the money to fix things.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
