9 minutes ago, TiTAN said:
But it has to appreciate to double its original value to cover the interest assuming you are just paying the minimum monthly with principal and interest.
As in over the 25/30 year loan period? historically haven't they been doubling every 10 years anyway?
You can only double every 10 years for so long until it's completely unaffordable for 90% of the market.
If all the places that are currently asking 1 million are suddenly asking 2 million you are looking at 10k a month for the repayments and a 200k deposit.
I thought this was VWL, 200k is pocket money m8
Seriously though, yeah I see what you're saying has to stop somewhere but we keep hearing that for how long now? Do people need to wait 10? 20? 30 years for this crash then another 5 for it to become affordable to them?
  • Like 1
4 hours ago, UNR33L said:
Why not just invest in property so you make some money
dezz likes f**king over other shareholders by investing his curse in their stock
  • Like 1
The 10% of the market who could afford in that scenario are pretty much the ones who have been driving it up in the first place. They have disproportionately expansive wealth compared to the rest. I agree it will slow down eventually, but for other variables, like a downtrend in foreign investment. I think majority market affordability will have little to do with it, without government intervention.
Also the more Melbourne sprawls, the more inner suburban properties will push up by virtue of comparison. I think it's gonna take a recession or a serious drop off in the rentals market to stop this train.
As for rentals, there's good reasons to rent, but don't fool yourself into thinking it's financially better over the long term than paying a mortgage, unless your interest is more than a month's rent for the same kind of place (unlikely). You might waste a lot of money on interest but you end up with an asset or at least a redeemable share in an asset.
Disclaimer: everyone's situation is different. Consult your product disclosure statement. Past performance is not a reliable indicator of future performance.
Find me a property that hasn't doubled in the last 30 years.... I'll wait here
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
