What scares me off crypto is that I'm overhearing guys at Christmas parties and the gym talking about Ripple and Ethereum and Elysium and Prometheus blah blah
These are seasonal and/or first time investors who are shaky at best which is likely why it's so volatile. Tons of money to be made, tons to be lost, but a hell of a lot of luck in that sort of environment just picking the right time or having faith that ultimately it's going to see-saw its way up. Investors are bad enough in tangible companies.
You can talk about Crypto's at Christmas parties not Casino bets :30_no_mouth:
There is nothing more annoying than the person that starts talking crypto to people they met like 5 seconds ago... On par with proud Facebook atheists that think they have evolved into super intelligent god-kings...
Hmmm maybe Hamish is right, maybe I'll sell everything and just leave it in a bank account and earn enough interest to pay my phone bill every month.
I never said that was the best plan.... But it's certainly smarter than pumping everything you have into crypto and never cashing out because you think it can never, ever go down.... Which is essentially the main thing keeping the bubble going... For now....
On 19/01/2018 at 10:48 AM, Birds said:
Why wait a day when you could wait a minute
You young punks and your instant gratification.
It's all cocaine, hookers and crypto alts these days.
I remember back in my day we'd need to settle in and wait months for people to lose their money on oil stocks.
  • Like 2
On 1/24/2018 at 8:19 AM, Leroy Peterson said:
You are.
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
