15 minutes ago, dezz said:
Ran over something, bent k frame bent transmission bracket, dented exhaust ripped the heat shield, slight gouge in the rear bar and probably broke some clips on the rear bar as it came out the back.. They said they were gonna fix it.. Few weeks later when it was supposed to be ready I get a call saying it damaged the floor and might be written off, 2 weeks after that it was gonna be repaired, another week or 2 later and it was written off... Damaged transmission tunnel etc etc
that is shithouse treatment.
just curious due to my Facebook stream of late, suncorp group insurance, ie AAMI/Shannons?
Racv.. Dealing with the call centre wasn't too bad, think it was more the assesor side of things is a joke. First off it was 'the assessor is on annual leave' like I give a f**k, get another one.
So from what I've pieced together now, initial assessor saw it after probably 2 weeks of sitting at their preferred repair centre, maybe not his fault claims hadn't told him it's there etc.. He was the one that said it might be a write off.. Then I think he went on leave, I told them that's not my problem get someone else on it.. That new assessor said it'd be repaired, which I wasn't happy about.. Waited for his call for 2 weeks, called racv and repair centre a few times, who both said we're waiting for the assessor.. Told them not good enough escalated etc etc.. Then yesterday was on hold for 20 minutes (to be fair pretty much the only time I'd really been on hold) got disconnected at 20 minutes, was going to call back and lose my shit, 5 seconds later assessor calls and says it's a write off.
Went to pick up my belongings that afternoon, and repair centre receptionist and guy managing my job both had no idea it'd been declared a loss as the assesor hadn't called yet, and they both made comments that lead me to believe he's pretty useless at calling people/customers back
Policy is new for old, but given they're out of production I don't think they'll be able to replace it.. Sort of suits me anyway. I liked the car, but don't really need a Ute anymore anyway.. Hopefully get the cash, buy a half decent ~10k run around to replace the current excel run around until I decide what I wanna buy...
4 hours ago, UNR33L said:
Had to do some work in the city yesterday, got back to the car at 3:35pm to find it towed and could see it down the road.. RIP $405 (Glad it was the work car and not my STI at least)
Expensive 5 minutes (turned to clearway at 3:30pm)
Well you know old mate was just sitting there with tow hook in hand waiting for 3:31 to hitch
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
