1 hour ago, UNR33L said:
Daniels donuts way better than KK
Used to live so close to Daniels when I was in Clayton, probably one of the big things I miss about the area. RIP
That laptop isn't bad for the price, rip out the shit 1TB hard drive and put a SSD replacement in as well.
So 4 months and they still haven't sold the place we are renting, hopefully they say f**k it and keep it for a bit longer. Asking way too much 890k for a 3 bed townhouse, yes its new but everything cheaply done and nothing special.
You'd be nuts to buy that when you can still get a ~600sqm block in parts of Vermont with an old dumpish house on it for around the same, subdivision STCA.
Both donuts are pretty Shitful, especially Daniels.
Like for real, its the same Donut with slightly different toppings.
Also unfortunately contract cancer every time I go near there due to the complete abominations in the parking lot, and their equally cancer-causing owners.
f***
  • Like 2
1 hour ago, Leroy Peterson said:
What are you trying to say about Bunnings Snags?
Nothing fancy about handing over $2.50 for a sausage in bread
I do remember when they were $1 though
  • Like 1
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
