On 6/22/2018 at 8:45 AM, Leroy Peterson said:
Tax folk: if company paying LAHA (the one that covers accommodation plus expenses) and its less than the stated ATO rate for that year, do you claim the price difference for every night its paid?
Nope
  • Like 1
Colleagues new Dell laptop had 2/3 working USB ports... Dell support comes out, cant fix it, so replace motherboard. Get laptop back, 2hrs later cooling fans stop working. Need to get support back out again...
And this is Dell Business.
when I was desktop support dell onsite support was great.
I'll call them once a week to tell them how many machines had died that week (usually 5-7%) and they would come out the next day to replace them. (I kept enough spares to swap out a HDD and get my end users fixed quickly)
within 18 months all systems had been replaced at least once some more than that..
Easy to be good at something when you do the exact same thing every week.
(in same time I had one service call for our IBM thinkpads. as some-one dropped one off a balcony onto tiles so needed a new screen)
  • Haha 1
Them feels when you get overnight parts from Japan (not really overnight)
Nothing too exciting, some genuine Subaru weather shields so I can be a cool subie brah.
Next up - Mudflaps (jokes)
But really why do they all love mudflaps so much? Do they actually drive on gravel all the time..?
You can even get matching colours :D
MF32_rallyarmor_mud_flaps_2015_2018_vag_
Edited by UNR33L
Be mad when my 12 year old Inspiron is still kickin along on XP with dem security updates
You can even get matching colours [emoji3] :
MF32_rallyarmor_mud_flaps_2015_2018_vag_subaru_wrx_sti_installed2_1024x1024.jpg?v=1528915253&key=2533f050e8015388a0724c047a713c3aaa00a6cf4bde1d24d72b6c70f0ed4721
Matching colours?!
Do it Leigh!
  • Like 2
I actually like the dirt flaps. Adds more character than the wang, thats for sure.
But yeah, weathershields are great.
Bolt on parts feel so good but then i feel guilt from "bought not built"...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
