so driving the astra on the weekend, going all the way down Mt Dandenong in the usual 1000 steps traffic, get down to the bottom of the hill and notice smoke coming from both front wheel wells. I drove a few hundred meters down the road to cool them a bit, then pulled over to have a look. They didnt seem that hot, and what was still smoking didnt look to be coming from the calipers.
Pedal feel is fine, plenty of meat on the pads and have done less than 20,000kms same as the rotors, brakes havent been touched in at least 2-4000kms, brakes are fine before and after incident.
Any reason to be concerned? could it be from excess brake dust on the wheels? (its pretty bad, but not neglected-euro bad)
I'm sure there'll be countless candlelight vigils held by Australian politicians and citizens in an attempt to spare their lives.
  • Like 1
I wonder if there will be plenty of bogans flogging the "do the crime do the time" / "their country their rules" horse
About as many as there will be high horse lefties drawing utterly ridiculous comparisons with Australia's treatment of illegal immigrants
  • Like 2
He's got you there leftish
meh... that was a stretch and you know it..
VWL engine swap day may not go ahead...for now.
Had a mechy pressure test the cooling system and check combustion chamber coolant...found a loose hose clamp that was letting air into the system. Engine now running cooler than ever thanks to the 1.3 bar cap (might put the old cap back on to get the temp up a bit when not doing track days).
However, there was a slight trace of oil in cooling system - potentially a slow head gasket leak or what he thinks could be an oil/water heat exchanger that can leak one into the other. May get an oil cooler to bypass this.
$100 later :)
  • Like 1
Anyone have a dashcam?
Tips or advice on a good one?
You must post every video of even the slightest mistake on the roads to a facebook page and act holier than thou
  • Like 1
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
