9 minutes ago, Leroy Peterson said:
Youre meant to be talking it up sky high. Or is this your actual opinion now that youve sold out?
Im sure the guys on HC would be pretty disappointed in you.
Well I never said my opinion can't change as the stock itself evolves in the market, but my opinion is the same...it's an awesome long term prospect...I'm just a trader at heart so my hesitance to buy in now is just me looking for the best entry point to maximise short term profit on a long term investment...doing this has made me more money than the other long term holders on 88E who won't play the short term game at the same time and miss opportunity for profits. But right now it's very 50/50 feeling, like throwing down money on red or black in roulette and if I wanted to do that I'd just take my cash to crown.
Forgive me if your original post was simply ironic humour that sailed over my morning head.
not my style, but cant argue with that price
http://page21.auctions.yahoo.co.jp/jp/auction/j404631818
Birds, time to move on from D1Rs
UFC203 on this weekend. Will make up for a stagnant 88E week. Dolla dolla Bill y'all.
  • Like 1
1 hour ago, Jonnoo said:
Basically at the very top of the pedal
Do you feel any vibration coming through the pedal? Problem with this pick up point is the throw out bearing can be held up against the pressure plate so it's nearly always spinning; recipe for a quick wear out
Bleed the clutch
Not sure if the pedals can be adjusted in these cars
Check to make sure someone hasn't put a longer rod in the slave cylinder too
Bleed the clutch
No vibrating
Mechanic bled the clutch when he put new one in
Pedal cant be adjuted
I dunno how to tell the difference in slave cylinders lol
Will google it when i'm not sitting on the side of the road broken down lel
got back to the mrs about 15 min ago
Asked a vietnamese resteraunt for a shifter and he brang me a spoon... (Seriously)
This is the 2nd time ive blown a hoseclamp off.. What causes this!?
Shit clamp, improperly seated clamp, silicon joiner possibly a few mm too big. I prefer them to be a tight fit. Like a virgin[emoji3]
  • Like 1
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
