Supercharger is really nice when someone in a Camry cuts you off or something and you need the instant 'f**k you' foot down smoke them up as you go around them.
Oh and going up the mountains you can basically sit in any gear you want
You don't get the rushing feel of torque like a turbo though, just because torque is basically flat through whole rev range, either will be a great mod.
Edited by UNR33L
Agree with Leigh - the choice between the two comes down to whether you want to go fast or feel fast
We clocked up more instant G force in my Skyline than his three hundred and seventy five kilowatts that walked away from me pretty easily
yes but how much of that was tyres ...  hook up lays a bigger part of instant g that power..
Was just foot down when rolling, both cars had grip.
Leigh's power delivery is just so linear that after the initial pull you barely feel it accelerating anymore...just see the speedo going up...probably also helps that you get to a given speed quickly so the feeling doesn't last as long either
Supercharging certainly seems more simple, less space, less heat issues, less custom work.
That pretty much is the winner for me. You can tweak chargers to suit your requirements and power curve with pulleys, belts and tuning?
If I'm gonna do it, should probably get it done before eofy.
Other thing to consider is warranty... Walkinshaw / harrop etc offer warranty, at a cost, haven't really looked into how it affects the manufacturer warranty if at all... But my mate recommended dynomotive or dpm, sounds like they offer more and better quality for less than walkinshaw etc...
I don't think EOFY really matters man... end of the day adding a supercharger to your work ute is not a deductable for a sparky.
Go the supercharger, you'll love it.
And yeah you can change boost by smaller pulley & the tune, e.g my car can be adjusted from low boost (3psi ish to 9psi ish stock standard) but if I want more than that I need to buy a smaller pulley to spin the supercharger harder. The problem here lies that then generally need the supporting mods like a turbo car, fuel pump, injectors etc.
That's great as long as you don't get audited.
Remember they compare you against the expected deduction for your salary & occupation class.
If you claim enough to stick out like a sore thumb it's going to be reeeeeeal hard to explain why you needed to add performance parts to your car that were not factory delivered.
2 minutes ago, Kinkstaah said:
Anyone know a decent auto elec that is mobile in Vic?
Not necessarily an "after hours cash only" style job, need a professional that can un-f**k a clusterf**k.
what happened? did you look at your car?
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
