27 minutes ago, UNR33L said:
Lets race!
I'll have to find a place to mount fire extinguisher in new car ?
Do they check dates? last deca I got through with an old one lol
Rumour has it I’m the scrutineer so yes
just grab a 20$ one and a seat mount bracket and your done no 2 bolts no holes or cutting needed
Eg
https://www.carmodsaustralia.com.au/fire-extinguisher-bracket-wrx-sti-2001-07.html
https://kap.industries/product/2015-subaru-wrx-sti-forester/
and there’s your next video
Omg Race prepping the sti
  • Like 2
Should be faster than the FPV around the course.. not as fun I guess.
f**k me $70 for a metal bracket, I made my own for the FPV.. might just re-purpose that if I can, I'll check out what the seat looks like.
Edited by UNR33L
Make it out of that bunnings bracket shit, mine still going strong after 7 years
From memory Subarus perform average at DECA skidpan in anything but the wet? Think they understeer the tighter turns...prove me wrong Leigh!
  • Like 1
I saw some thing with a v8 supercar driver in a sti showing a normal guy how to go faster, the main thing was not to worry about the entry speed (more entry speed or trying harder more understeer) and worry all about the exit speed / traction out of the corner, was proven with lap times too.
As Martin said looks like they wet it anyway, FPV was NOT fun in the wet parts at DECA that time ? shit was like ice.
Edited by UNR33L
Wet skidpan? RIP pulsar
Also, surely someone on subie forums got a bracket design.... Model cant have changed that much in last few years... If its subaru probably hasnt changed in 50years
Got onto a friend thats selling his car said I could have it so all sorted lol
Edited by UNR33L
i'm a little disappointed, this was my last chance to kill the tires that would not die..
before I get something that actually grips again.
Can always have an unintentional sustained loss of traction while stationary to kill them.
Throwback to 10 years ago probably tonight
Member #211 at the sauvic monthly meeting off Moray St asking "what about GTS-T owners" when the GTR hoodies were revealed to the club
  • Like 1
  • Haha 1
I'll register soon, can i just pay renewal membership or do i have to pay a whole "new membership"
I have a membership number etc just havnt paid in a couple of years I guess.
Edit: Membership number is 404
(not found lol)
Edited by UNR33L
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
