Anyone using bosch top feeds? And what other brand, apart from IDs would you say are the best/smoothest etc ?
So far as i know Ids are Bosch injectors. I am a great believer in getting expert advice and one expert on here is Scotty so just ask him for his suggestions (and then go with them).
I stand corrected - I was not thinking clearly when I posted that, let me clarify my meaning..
the stock reg will handle a stock fuel pump, and stock lines, and small - to medium - sized injectors.
when you change flow rates/volume you will need to calibrate.
Edited by SilverECR33
Even that's not really true.
The stock reg will handle arbitrarily large injectors. It does not really care how large they are. The limitation on whether the engine will run properly with big injectors is the injectors themselves and the ECU.
The stock reg will handle a very large increase in pump capacity. Many people are running pumps with more than double the stock flow through the stock reg.
The size of the lines doesn't really matter either - the reg doesn't care.
The only time you need a bigger capacity regulator is if you are hitting it with more fuel supply than it can flow back to the tank. The only times you EVER need an adjustable regulator are
a) when you have no ability to tune the ECU and need to trim total fuel supply, or
b) you are at the limits of your injectors and need to squeeze a little more flow.
Other than that, there is not really a need to adjust fuel pressure at all, especially these days.
  • Like 2
^^ Totally agree, unless you need more pump flow. I usually lower my base pressures as I always go overboard on injector sizing anyway. Can make it easier to tune large injectors also.
Just remember Dale, the fuel pressure raises by one psi for every psi of boost. If you run 45psi base, and add 35psi boost, your WOT fuel pressure is around 80psi, past the limit of what most pumps want to flow efficiently. Hence I drop my fuel pressure to 35psi, as it's wasn't unusual to see 40 psi boost on the soft limit. If you google a few common pumps and what they flow, most don't like anything much over 70psi, the flow drops right off. For most guys it doesn't matter as their boost level is reasonable.
Most injectors get lazy at high pressure too, taking longer to open, sometimes intermittently due to the pressure pushing on the valve shaft. It would get worse the larger the injector I suspect.
Anyway, the stock Skyline fuel system is well sorted and can bypass enough to run a Walbro 460L pump, which could flow near 600kw on 98 I suspect. The same can't be said for the Evo, every car is different, that's why if you are going to muck around with regs and large pumps you should really be monitoring the fuel pressure on the dyno just to be sure. Ditch the stock fuel filter though, they aren't usually up to the task.
If you want a good injector, the new ID1300's or the Bosch 1650's would be the pick, twice the price of a set of modified 1000's though. All are long term ethanol safe, unlike the 2000cc gas injectors.
Stock reg might get silly if you're running twin pumps into it as there's huge amounts of fuel flowing through it.
Even so, I've seen GTRs running the stock reg with twin Bosch pumps going to it without issue
gtsboy your clarification was not correct. flow is important, line size and pumps are also important, ecu and trim cannot fix baseline, the stock reg is not adjustable , and as scotty as rightly also pointed out, boost compensation needs to be taken into account also.
thanks scotty, I remember now. busy life, busy mind.
I was sure the op was doing some upgrades? I didn't realize we were trying to run stock power with large injectors.
but sure GTSboy the stock reg will work great.
  • 3 months later...
I ended up going the 740 Nismo to keep it stock looking (which it does very well). Chequered Tuning did the tune and so far Im very happy with it. Drives better than before around town and manages the power well too. No problems
Sooooo much this.
When the Walbro's came out (the 260lph ones) everyone was jumping up and down about how good they were vs the Bosch (and cheaper).
Yet once you were running ~16psi+ on a RB you suddenly ran out of fuel because the 260lph flow rate was calculated at 35psi or similar. Where the Bosch was rated at something like 70psi for it's flow. The 260s were only good for low boost/N/A applications as a result (for the most part).
  • Like 1
Are top feed more superior than side feed injectors? Reading this thread has made me regret a few purchases. .. especially when reading the word "outdated" :/
Not inherently. Go back to the early 1990s. RB20s had top feed injectors. The RB25 changed to side feed injectors. The underlying technology in both was approximately the same.
Fast forward to now. Any side feed injector you buy now will be based on the same old (OLD!) designs that were in use in the early 90s. Meanwhile all the new Bosch (and others, like Siemens, etc) injectors are top feed. The newer designs are far superior to the old ones (regardless of whether the old ones were top or side feed). So consequently, yes, top feeds are superior to side feeds, if the top feeds you are comparing are modern.
I have the Nismo 740cc in mine, bought them second had with <2000kms on them had them cleaned and tested. Idles pretty bad when the car is warm (splutters etc). My tuner said it's the injectors. If I were to do it all again, I would go top feed rail and injectors.
Nismos run and idle perfectly, either their not clean or tuner hasn't done a good job if cant get nismos to idle well.
  • Like 1
idle them a little richer, will idle silky smooth OR just go to E85 as you need more fuel on idle so they atomise properly lol
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
