Ask 10 people what's the best oil, you'll get 10 different answers.
Don't stress about it. A very small percentage of people are oil nazis, and they can go read bob the oil guy all they want.
For the rest of us, a reputable brand 5w-40 or 10w-50 is fine for 95% of drivers here.
https://www.sau.com.au/forums/topic/458795-oil-replacement/#findComment-7581640
thanks steve and alex , I have some info,the only reason I ask is im about to install a new oil cooler and oil pump and filter relocation kit.
engine oil
MOTUL 300v 20w 60
Castrol edge 10w 60
gearbox
redline mt 90
attessa
nissan oem d matic
diff
motul gear 300 lsd fluid
also royal purple has been recommended
https://www.sau.com.au/forums/topic/458795-oil-replacement/#findComment-7582007
I have MT90 is my S14 box, going to dump it shortly, seems to be too thick for the application
Hard to shift into second when cold, gets better when warm but still not as what I would have liked. Really sucks taking off from a set of lights and trying to force it into 2nd, while some daewoo is tailgating and trying not to crunch the gears
https://www.sau.com.au/forums/topic/458795-oil-replacement/#findComment-7582235
I basically went to autobahn grabbed motul full syn gbox, engine, diffs , coolant, everything, cost 500 got a 100 discount for spending so much.
I'm a MOTUL biased whore.
tracked all my litre bikes for years on the shit and never had an issue so I just stuck with it but there are many good full syn oils out there now days..
https://www.sau.com.au/forums/topic/458795-oil-replacement/#findComment-7583048
no worries skidza ,
any problem with filter relocation kits ?
as a mate said his motor rattles for the first few seconds ,until the pressure builds up ,
I thought there would be oil pressure in the lines.
https://www.sau.com.au/forums/topic/458795-oil-replacement/#findComment-7591346
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
