Your plan sucks.
ps. Thanks for not being TOO direct in your answer/opinion(that's me taking the piss now). A simple "maybe not a good idea" or "too costly" would have been sufficient. Edited by MR PHATT
Thanks for the tip.
My thoughts are this atm=import clean r34 gtt-auto, mod to the max, if still having issues with trans box by start of 2016 then convert to manual. Any thoughts? I know manual conversion is pain in the a$$, but any one have price estimate?
This is literally the worst idea on the forum in terms of start to finish
I'm going fishing, should I get a manual reel or an auto? And what should I catch?
PHATT you shouldn't ask ppl to help you plan, you should have a plan and then see what is wrong with it.
I'd be more concerned about turbo, IC, computer, dump/exhaust, injectors, pump, brakes, suspension, etc etc...........Theres $10K in that alone.
Your a long way away from maxing out a GTT in manual or auto TBH. Work at the basic things and get them sorted first.
No wonder they are razzing you, its these sort of threads that make their day.
  • Like 2
true & thanks
Ok, ok, guys I know I went a bit off track & probably deserve a bit of s$&t stirring at the end, haha. I'm bidding on car later tonight(think manual) & have another in Vic I'm viewing(auto) on w/e. Both gtt. Going back to my original question=I just wanted to know if autos & manuals had similar hp capabilities, yes Ben & Hadouken "Mod to the max" capabilities haha? To help me decide which one
as soon as I posted that last idea I regretted it, was bad idea. Now knowing you have 400rwkw auto, & how much you've spent, I know not good idea at all
It's very easy to poke fun and have a lols at others who are just starting out and asking (what to more ... learned posters) can be silly questions
When the truth is you're likely just enthusiastic and excited and looking starry-eyed into the future of a nice well sorted high HP enjoyable skyline
well, let my jaded, aged eyes be the voice of reason and say OH SHIT SON BUY A f**kING MANUAL.
Better yet, buy someone else's project.
The way you're going about it is all wrong, has nothing to do with auto or manual.
  • Like 1
Cheers Kinkstaah. I am excited & realised I am jumping the gun. Was just so happy to sell N/A 34 & jump in to turbo. I understand it's a long (& expensive) road now.Taking all on board, thanks. Ps. Last import looked I had to say no as had a Nismo S tune body kit(did no like front bar) & big ass wing, was disappointed. I am now looking at others projects also.
At least you're selling the N/A and getting a turbo.
Do the smart thing and read read read. There's a clear upgrade path almost everyone follows on a long enough timeline.
Going to that point directly will save you many tens of thousands of dollars and years of labor and pain.
It could be argued that no one would do that/see the value in it until they've already done it the hard way once first though.
  • Like 1
N/A got sold. Will do Kinkstaah, & have been trying to read through as much SAU threads as possible & will continue to do so. Thanks mate. Ps. A bit off topic but if anyone in Vic & in to Muay Thai & mma-on 22/8 at Doncaster will be a few of my training partners & friends fighting. Will be good night & will be good to meet some of you guys
Edited by MR PHATT
sorry fights are in Kengsinton-Melbourne Pavlion.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
