So after a stupid long wait, my wheels are here. I finished up everything i needed to do underneath the car, threw the wheels on, and washed 6 months of shit off it. Still looks like poop, but paint needs to be wet sanded and buffed, as its still straight off the gun, and then tidy up some bodywork and stuff.
I need to adjust the coilovers and all the suspension arms etc, and Im able to pull all my rear camber out. And good front rubber means i can add a heap up front now.
Still a minor couple of bits to do, and then it can go off to be wired and tuned. I fly to newcastle on monday for work so i won't get it done for a couple of weeks, but seeing it back on the deck makes me want to smash it out even more.
Then comes the fun part... testing and driving!
Edited by R31 drift pig
  • Like 2
Thanks Jonas!
My new job give me some more money to work on it, so ill be changing a few things I'm not happy with, like the fuel system in the boot, and my cooling setup (intercooler/power steering/oil cooler) Ill be changing them up a bit, also i have found a non HICAS subframe, so Ill probably put that in with some toe arms, and sell my drag links, and maybe run some new drop knuckles front and rear so i can put some more preload back into my coilovers.
Ill sit down and have a good look when i get home.
My Drag links replace the HICAS and allow toe adjustment, but the GKTech or Driftworks Rear knuckles require actual toe rods, so I may as well do it all in one hit. Trying to also retain as much grip as possible and increase roll centres a bit, while still being low.
The Rear knuckles also have dual rear calliper setup, i may remove my drum handbrake and go to a hydro setup. I have a new set of cables and a new pair of Project Mu shoes to go in already though so undecided.
  • 3 weeks later...
Definitely, Im just finishing off some stuff and making a few changes, Im intending on getting some street time in for a bit first, and should have it out @ the Skyline Nationals here in SA in october.
If you see me or the car, come and say Hi!
Im hoping the car will be quite capable at a few different things, although Im aware they are all very different disciplines requiring different setups.
I was originally intending on hillclimbs, maybe a few circuit sprints (But they don't really interest me TBH) maybe some more drifting, but not really 100%. Just want to have a heap of fun I guess.
I haven't done anything about the drop knuckles yet, I'll still do it, probably just at a later date. Im pretty keen just to drive a this point and make gradual changes on a setup I've had 2-3 years already driving, rather than change EVERYTHING at once and have a lot more difficulty trying to get everything right and chase my tail.
All I've really done from it being my daily/streeter is strip the interior and add a cage/seat, change the wheel and tyre setup, add a set of front knuckles, and add about 50-60kw with cams/new ECU and E85. Thats about it really. (In reality i actually tore the car down to a bare shell and then put it all back together) :rofl2:
Im in pretty much the same boat haha. Street trim to caged with slicks, haltech etc... just doing aero on my car and being able to drop it a heap would be awesome but going to go get some MCA reds first i think. Should look at Masters of mallala and come out in the Sport sedan group
Circuit racing doesn't really excite me to be honest, although I haven't done a heap of door to door. I've done a few circuit days in the 33 when it was a streeter and it was fun, but not enough for me to solely concentrate on.
I think I'm more inclined towards hillclimbs and maybe Tarmac rally or something.
I may look into MOM though, might be something I might find interesting?
  • 3 weeks later...
So car is booked in for wiring and final tuning on the 25th of this month, should only take a week or so. Pretty damn keen!
Just finishing up the last few bits and pieces like my door trims and finishing off the cooler piping and going over everything. Then just an alignment and can get some driving done!
  • Like 2
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
