So as I'm doing a bunch of work on the car, I thought I'd make sure it was e85 ready if I want to go that way in the future.
I currently have a teeny low pressure/high flow pump in the standard holder in the tank (nice and low) and a good old bosch 044 under a surge tank that sits under the rear sear outside the car. It's a great setup but AFAIK neither pump will survive if I run e85 through it.
What are people using for e85 safe lift pumps, and are there any external pumps similar in size to an 044 (so I don't have to stuff around with the setup too much)? I bought the big e85 walbro but it doesn't suit external use and is crazy big to use as the lift pump (who wants to warm and circulate that much fuel.....
Car only makes 310kw at high boost on e85 so it doesn't need 400kw+ pumps.
https://www.sau.com.au/forums/topic/460575-e85-lift-and-external-pumps/
A walbro 460 will fit with another Nissan cradle intank. (I have one in the 33, not sure what/if there is a difference in the 32 with the different fuel tank setup).
Have a look at the Holley dominator 1800 for an external.
A bit more work, it will work and is quiet.
Talk to Unigroup about the specific cradle to use
Walbro 255LPH 500HP External Fuel Pump GLS392 is ethanol rated
http://www.trademe.co.nz/motors/car-parts-accessories/performance/fuel-systems/auction-967861260.htm
According to NZEFI the Walbro in your tank (GSS341 and GSS342) is ethanol compatible ( I have run E10 though mine with no ill effects)
Check with Scotty - he will know and also has pumps at a good price.
My 255 twins are still going strong 6 years on in the Stagea, I guess I have proven they are long term safe. :P
I am using a peirberg in tank lift pump (part number 721.088.62) direct fit into cradle, e85/methanol safe, into a surge and a 044.
044 will be fine with e85.
Edited by R31 drift pig
  • Like 1
Flow rating of peirberg? (I know I'm lazy [emoji14])
200 LPH at free flow, 130 @ 3.5 psi. About half what a single 044 does at full noise - mine will be 280 lph @ 65-70 psi.
The 32 is different to the 33-34 setup, but that is the system I will be using once I purchase the 1800 dominator pump to replace my loud az fark Weldon pump, as I already have a Walbro 460 intank as a lift pump, was looking at Fuelab but have heard a few horror stories about them lately
Duncan, given it is the engine that primarily heats the fuel having a high flow intank lift pump circulating cool tank fuel through the surge tank can't be a bad thing, if the intank out flows the main pump then the engine return line can be plumbed back to the main tank so the surge tank is always full of the coolest fuel possible
  • 7 months later...
Hi, I have a nismo internal pump and a Bosch 044 external pump from a surge tank. I installed it after having fuel surge issues and it fixed them. I run e85 and am concerned about the longevity of the Bosch 044 pump.
I was wondering if it was possible to use the walbro e85 intank pump as an external pump as a replacement for the Bosch 044?
Edited by boxheadmr
I run the exact same setup on e85 in my track car for past 5 years and both pumps the nismo and 044 are still alive and have never had a issue with them yet.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
