What about NISMO injectors? They're junk Sard garden hoses with a Nismo sticker.
Their suspension arms. Cost a bomb (or as much as Ikeya stuff) yet you don't have anywhere near the adjustment. Painted silver but!!
The list could go on forever.
They do make some decent gear like the rear diffs, clutches and are actually reasonably priced. Most of it is just "warmed up" and hardly worth the money.
But you have a NISMO clutch in your car?
Just like most of us did/do...
At least they got one thing right
Last paragraph mate.
Not saying it's all junk. The diffs and clutches are fantastic. Absolutely no question there. That clutch is THE clutch to have one a street GTR.
  • Like 1
Lots of Nismo hate... And I've bought two Nismo items in the past 4 days [emoji15]
One of those items was a fuel pump... I can't bag the price of Nismo too much - the identical Tomei fuel pump was double the money of the Nismo!
  • Like 1
I installed a Nismo thermostat in my R33. Was great, car never got the chance to get out of cold tune! And it only cost $120!
So glad I didn't spend $40 on an OEM thermostat that would hold a collant temp over 60 deg C, fuel economy is for chumps!
/Sarcasm
  • Like 1
Walbro would be half the cost and flow even more and be e85 compatible.
Won't be a direct fit i suppose though
a hose clamp and 2x wire crimps aren't exactly brain surgery lol
  • Like 1
Maybe not, but I've read mixed reviews on Walbro pumps, where as I've heard no negative comments about the Nismo pumps. It also includes everything for a painless swap, including the large o'ring that seals the fuel pump opening. The flow of the Nismo pump is a good match for the rest of my gear (injectors, turbo etc) so the higher flow rate of the Walbro would be a waste.
Hard pipes usually do the exact opposite - in that - they make shuffle far more pronounced/problematic. Particularly when running larger twins, stock turbos not a problem but upgrade to -5s or 2530s and you're in for a tuning headache.
So no, they are certainly not a good upgrade IMO. Plenty on this forum have even REMOVED the hard piped and gone back to stock ones for that very reason, plenty of posts about it. So definitely something that article fails to touch upon but then he's still running stock turbos... They should be the first thing you change, not everything else first.
Just curious, why do the group A R32 Gtr such as the Calsonic and Gibson motorsports have the hard pipes then? I thought the hard pipes gave less flex compared to stock rubber and had better merger Y pipe before going into intercooler?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
