Just you saying that it will "smack" a gtr shows you're most likely a p plater that frequents stereosonic and muzzes out.
What makes it so rare. Enlighten all of us
  • Like 1
I heard this exact car bet an R35 the other night. The R35 was parked, but that doesn't matter, right?
Yeah that was my r35. I know wish to swap it for his freak rare na 180sx + cash his way.
http://www.sau.com.au/forums/index.php?/topic/461997-94-180sx-Fast-Reliable-Club-Trackday-Car-With-Rego---Nsw
Soo much better then what you are trying to sell and for less
If you are dead set serious I suggest you should do more research into what something like you have is actually worth.
Every 180 on carsales bar 2 is cheaper and better then your car
  • Like 3
so the choice is...
fully built track ready 180 for 15k with 290rwkw
or
hacked up n/a 180
rusty with a cheap paint job
slapped together with random secondhand wrecker crap (and still incomplete)
...for 16k
:domokun:
Edited by junkie
  • Like 1
so the choice is...
or
hacked up n/a 180
...for 16k
:domokun:
Junkie the way you describe this sounds oh so compelling... I'll take 3 of them!
come on, we all know it's a troll, with another supporting troll account to back him up. close thread and ignore
actually the supporting troll is a real person who popped up on a few mutual groups on facespace.
Guys who think this is a troll should just F off...honestly. Can't i sell a car on here without you Aholes ruining everything......GET A LIFE PLEASE
for those who are interested, the car is making 330kw at the rears on 98 octane fuel, a true N/A powerhouse running nankang street tires on the rear for extra grip
Tuned by Garage worx
the paint for the respray is genuine from nissan Midmight purple 2.... cost me 1k just to buy the paint and then 2k for respray
Genuine Nissan paint for 1k? wut
330kw on N/A? wut, Got dyno papers?
In all seriousness, you can import a Type X with the proper turbo engine for 11-12k...
http://j-spec.com.au/recent/1997-NISSAN-180_SX-_Type_X_H_intercooler_AS-187108.html
facepalm
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
