SAU Nickname: J-Boy
Car Make and Model: 1990 GTR32
Circuit Name: Queensland Raceway
Lap time: 1min25.40s (National) 59.81s (Sprint) 1min4.3s (Clubman)
Modifications
Engine: RB26DETT
Power: 315kW
Suspension: Buddyclub P-1 Race
Tyres: Various
Brakes: Standard
Body weight: 1400kg
Lots more room for improvement for the car and driver i guess, wished the boost controller solenoid didn't give way during the last timeattack session when i was out to test the revised suspension and alignment settings, but well shit happens. Lap times above were done with very unsorted suspension and alignment, but with regular high boost. Most recent session with revised suspension n alignment, but with stock boost, best time was half a second faster on clubman.
I need better brakes and fresh semis!
Car Make and Model: R32 GTR
Circuit Name: Wakefield
Lap time: 1:10.34
Experience: I know this track very well.
Circuit Name: Eastern Creek
Lap time: 1:55.3490
Experience: My second time there.
Oran Park GP coming on the 16th....
Modifications
Engine: RB26DETT 2860-7 turbos 18psi, full 3' exhaust, standard ECU and fuel system, oil cooler. Notable Consult results = 98%duty cycle on injectors and almost 98% on AFMs.
Power: 240awkw.
Suspension: k-sport coil overs?
Tyres: RE55's all round
Brakes: standard R32 calipers and disks. Red stuff pads and top shelf fluid
Body weight: standard plus my fat arse.
Ok, we should know by end of June whether a std RB20 with a bolt on turbo setup, good suspension and good brakes can do a 1:20-1:21 at Sandown and a 1:49 at Phillip Island :)
Spend required :P
Brakes - $2000
Suspension - $3000
Tyres - $1500
So fark me, $6500!!!! Hopefully i can sell of some of the current gear i have, like seats and wheels to help pay for it all :) Its beyond me how ppl can afford to mod their road cars so quickly >_<
And thats not even allowing for the repairs/respray of the bar and guard :angry:
16 Piston Alcon brakes off a Peugot 405 Super Tourer :) Ive got more pistons in a caliper then most GTR guys have on their entire car :)
Lol, If you beat my 1.21.3 @ Sandown, i'm finding a 2nd hand stocker and throwing that in and having another crack at it.
Actually what am I talking about that was on std turbs and std brakes. Go nuts bris.
Hey, my car has plenty of stock gear on it. We will know soon enough. The match race is on. I will be running the next Sandown with teh same brakes as you and the same suspension as you. So shoudl be an interesting comparison of a 260kw R33 GTR vs a 230-260kw RB20 R32 GTSt
I should add you are sooo GAY if i get near your lap time. R33 GTRs being so superior to an R32 GTSt, and lets not forget the superiority of the RB26 compared to a lil std RB20! :)
You still havn't learnt have you? You start the sh1t talk after you get the results, not before!
Bris - if we could get Benno, JFK, Marcov, Frank, Crazy Tony and Vossy to post up their times you wouldn't have a hope of getting near the top 10. Infact that'd mean you'd need to run a sub 1.20 pretty much to make it.
Where'd your RB20 be then hey?
LOL...you wouldnt be in the Top 10 either :)
But in all seriousness if ppl know enough about their cars and times we should add them to the list. The point of this thread is to gauge yourself on what tims your car should be doing with certain mods. But most importantly where best to spend your money to go quicker based on the results of others.
The more quick tmes the easier the shopping becomes
Yeah I wouldn't be in the top 10 but I'd know I have a chane of getting back in there :)
Anyways - a quick run down of those times for the other cars
1. Marcov - R32 GTR - not sure other than full race trim, big single and RE5's - 1.15.9
2. Benno - R33 GTR - RB30DET, truck turbo, harrops, etc etc- RE55's - 1.16.8
3. JFK - R33 GTR - Twin 2860-5's - race trim - Hosiers - 1.16.8
4. Vossy - R33 GTR - HKS 2.8L with 2530's - RE55's (?) - 1.17.1
5. Tony - R33 GTR - twin 2530's - RE55's - 1.19.75
6. Frank - R33 GTR - twin 2530's RE55's - 1.19.xx (can;t remember as it was in the practise session and then his clutch went bang)
ouch!
that's gold. nice one snowcone. :D:D
i reckon maybe now we are getting lots more times we could expand to a top 20 to give retards like me and troy a chance of getting back on there!
Bris,
I reckon Richard is spot on there. Like you say if the point of all this is to see what mods made a car go faster there is no point having the slowest person doing around the 1.20 mark around sandown as most people who are just starting out will be no where near those times.
+1 for the lists to be expanded to top 20 times (where needed!)
Why not have a mod top twenty and then a standard top ten... so guys running stock turbs and street tires can represent hahahaha... I might actually make THAT top ten (although Gareth will have top spot locked down!) ...might also be easier for the new guys to work out what kind of times they should be doing etc...
also why don't the big power GTR guys try running slicks instead of semis? Troy that could get you the few seconds you need to topple some of these guys and I don't think anyone would begrudge you slicks if your still running the RB20!
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
