Hi all,
I have recently had my BNR32 Vspec tuned.
Its set up includes stroked 26/30, 3.2L with twin low mount Trust t618z-10cm's.
The power made was 559.7hp atw on 18psi. The ignition started to play up, as they are the original coil's.
Question? What will I have to do to make a HKS twin power with BNR34 harness work in a RB26 from a BNR32? is it as simple as installing the Twin power to some R34 Coils and plug the harness in?
Any advice from experience would be greatly appreciated.
Another option that may work out cheaper would be to swap to LQ9 (LS truck) coils.
Great looking car by the way. Where did you get the bonnet from? It's a style I haven't seen before.
Edited by Ryno
Even with 3200cc those turbos aren't all in till 5000rpm? Good golly they are such rubbish.
Anyway, as others have said - try out fresh stock coil packs first. If problem persists, go after market if replacing at your power level. Might as well :)
HKS DLI was good 10 years ago, but the world has come a long way and there are better/cheaper offerings out now.
  • Like 1
D585 LS2 truck coils, www.ls2rb.com, bit of wiring to remove ignitor and more spark energy you should ever need
this or splitfires, sometimes we need to not make mountains out of mole hills people
Well, these two solutions are, in order from the 2nd quote upwards, 1) the easy good workable solution and 2) the bit more difficult, bit more involved but technically better solution that really doesn't cost much more and is highly recommended for those who intend to lean hard on the boost.
You makes your choice depending on how much effort you can put into it vs your intended usage model.
Don't forget to replace your 25 year old crusty/burnt coil pack loom.
Wiring Specialities do a replacement loom for less than the OEM loom and I dare say is of the same quality if not better :)
Both non braided and braided versions too.
http://www.wiringspecialties.com/wisprbcohabr1.html
God damn the RB25 one is cheap - Do you know what they are like with shipping mate? i.e will they ship to Aus/is it expensive to ship?
Cheers
Cost $480 for everything with new coils and an hour with the soldering gun, had the whole conversion done in an afternoon
$100? What's delivery? + exchange rate, sounds like it'd be more?
OEM from Nissan AU is only $140... Well, that's what I paid when I got mine for my RB26 5 years ago, I doubt it's gone up too much in price.
I use Ignition Project / Plazma direct coils as a bolt in solution that uses an OEM loom. That and copper BCPR-7ES plugs gapped at 0.65, no sign of ignition issues at all. 705hp atw.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
