Hi All,
Got my V36 dyno-tuned at CRD yesterday.
Combined with just putting some dry type cold air intakes on it (no other mods), it has tweaked the performance of the car to how I would like it to be with minimal cost.
It removes the throttle lag you get standard with this car and it feels more like it launches more. It has a 'Raspy' racing kind of sound now through all gears.
The dyno print out shows about a 10% gain in power and torque and increased top speed.
It has also made the paddle changes more punchy.
I recommend it as the first thing to do to anyone who has a V36 stock standard as it changes the whole feel of the car.
Cheers.
Did they reflash using ECUtek like mine was? Post up your dyno graphs like I did in 2014. I'd like to compare.
Have you got a link to your graphs ? I would be keen to have a look thanks
OK did sound like a cool story. While we are judging some of you need a hug.
Got the intakes off AsM. 'Satisfaction' Cold Air Intake Systems. You can see on You Tube. The intakes changed the sound of the car.
Anyway that's all I wanted to do to my car so I'm happy with it. They probably flashed it with UPREV and told me it was a dyno-tune, but that's the art of being a mechanic.
For me I'm loving the torque, throttle response and power off the mark, particularly in paddle shift mode as I have an SP.
Attached is the dyno-graph.
I had the "03" 350GT Skyline and put the APS Twin Turbo System on it, only took it to 253awkw I asked for a mild tune, the turbos kicked in early , it was a fun car to drive. Added attachment, just loved that blue
While I was getting some work done on my R34 Jim mentioned something about a different chip for the 350GT that helped maintain the tune or something like that and was a good addition, maybe they have something for your model, ask Jim.
All the best
Edited by Nismo 3.2ish
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
    • What do the spark plugs look like after you tried to start it with everything connected?
