HI,
I have a 94 GTST. Finally getn my ass into gear and do some upgrades.
I had thought, bigger turbo, front mount etc etc.
Any other ideas of what i MUST do?
Any comments at all.
cheers
ben
wait, you can mod skylines?? why has no-one ever posted about this or made a guide about basic upgrades????
now THATS sarcasm.
hey, you do say "Any comments at all." so input is valid, no returns accepted.
https://www.sau.com.au/forums/topic/462644-r33-upgrade/#findComment-7676355
first thing you need to do is learn to use a search bar.
second, it's your car so do whatever you want. nobody can tell you what you MUST do, thats just stupid. sell it and buy a ferrari, its cheaper.
You need to know what YOU WANT before YOU can decide what to do.
https://www.sau.com.au/forums/topic/462644-r33-upgrade/#findComment-7679692
Hey buddy. Dont be discouraged. Basic mods like air filter, 3" straight pipe and better spark plugs will help. It all depends on what power you're looking for. Simple search will get you wherever you wanna go. :yes:
https://www.sau.com.au/forums/topic/462644-r33-upgrade/#findComment-7680490
