How is this possible i cant get more than 405rwkw turbos apparently outa puff ... built motor fair bit of head work although std actuators and inlet. I call bs unless huge intake work
Fuel
Exhaust
Intake mods
Cams
Head work
It can be done, but the right parts need to be employed.
List everything...
Once the turbos are out of flow you can then make more power by using what they flow more effectively/efficiently like comp ratios and cam timing etc
E85 helps here to
but how will the exhaust gases get past the 2x restrictors?
unless you twin externally gate them.... then you might as well just get a single :)
  • Like 1
But don't you get into issues of spinning them too fast with a bang to follow?
Depends on engine size really, 30psi on a 2.8 will make them spin to fast, 2.6 not so much but yeah still getting up there
Also by making the engine run more efficiently means the turbos don't have to work as hard for the same power
I have made 458awkw from GT-RSs on my 3.0 which run the same exhaust as -5s and Piggas has made 473rwkw with -5s on a 2.8 and I have been talking with a dude the has made 716rwhp from -10s on a 2.6 so I guess it comes down to how much power you want to make
you "could" do this.. 3" dump -> Cat (because we are sensible) -> 3.5" Cat Back... plumb gate back into 3.5" cat back.. bypassing the cat :)
legal enough.. at EPA they won't be cracking gates.
What was the cause for yours to hand grenade
Who knows, bearings were perfect, no oil stavation or heat damage apparent. Running 26 psi on a built 26.
Everyone threw their arms in the air, no one's fault and said show me the money for a rebuild. [emoji19]
Going single also can be risky if your not willing to external gate to atmosphere, i know people who plumbed back gate into 3" exhaust and wonder why its a laggy pig.
That's not risky, that's stupidity. Change 3 inch to something that belongs on there. I bet everything improves.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
