I'll be nice and let you know a small part of where you went wrong in your post.
We don't even know what car you are talking about or what engine is in it. That's your first error...
There are so many variables that come into play so you might want to do some searching first and come up with a specific question if you really cant find any info, but try first =)
There is no way for anyone to answer your OP.
https://www.sau.com.au/forums/topic/463211-what-boost/#findComment-7688928
For example 800cc injectors implies you have a massive turbo. So what kind of turbo do you have? Have you got an aftermarket ecu? Does your car go? What boost are you running now? Have you got a forged and balanced RB30?
  • Like 1
https://www.sau.com.au/forums/topic/463211-what-boost/#findComment-7688948
Big dose pipe
OK time to be serious, you can't really say how much boost can I run on stock internals.
I personally put about 25psi into my motor but I run a turbo that needs that much boost to deliver the outcome I need.
If I ran a larger turbo and put the same amount of boost into my stock motor it would end up in a pile of scrap metal.
https://www.sau.com.au/forums/topic/463211-what-boost/#findComment-7693214
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
