Most people here would recommend the Quaife front diff over the nismo, as its a helical type diff instead of mechanical plates, helps with understeer under load. Also my diff guy doesn't like to install mechanical fronts as too much of the diff housing needs to be ground down to make them fit apparently
Additionally, note that for the gtx turbos, they aren't a bolt in affair, to get mine i needed to find a rear housing to suit and then get a front housing machined. As was mentioned in the first page, you should probably be able to get a turbo shop to do that using tx 2863's into your existing turbo housings. why not 2860's? because you cant machine something to be smaller than it already is.
You mean you'll get more lag and shift the mid range higher up the RPM..
Longer duration cams are not the answer to getting better response or making better mid range.. Yes you will make more torque yes you'll make more power but not where you want it.. and that's nice and early.
I have 272 by 10.8 cams on a 2.6 with -9 turbos and have full boost 21psi by 3800rpm on 98
put some smaller cams in you will get even better response.. and welcome back lol.. you went missing for a while
Check my build thread for very detailed Nismo install instructions including highlighted areas where to grind. It was not significant by any means.
Regarding the clutch diff vs helical...I think the nismo 1.5 instructions references that it is a lightly set clutch style...not crazy deceleration lockup (but I haven't driven mine yet). I'll let you know when I drive it.
I would also have chosen quaife but I would have had to become a dealer in the USA and buy 10 of them to get one!
Also nismo came with the bearings and seals. I don't think other ones do. (Tomei, quaife, etc).
Also don't forget you will be buying / ordering shims. The setup took a bit of time for me. I had to make 2 shims.
I understand there will be lag, but there is acceptable lag and a dyno graph that looks like a cliff face. Nothing and everything for a split second.
Dynos gives u info in one gear and WOT.
On the street you never load up 4th at 2000 rpm at WOT and wait for boost. Real world is different to a dyno.
  • Like 2
Also the EFR are literally the fastest responding turbos on the market right now. Geoff at full race made 704whp through the 8374 EFR on a stock bottom 2.6 with lots of headwork on E85 through a cat.
wow.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
