11 hours ago, Forgeperformance said:
I saw one for sale in sa  a few months ago. Missed out by 10 minutes haha. How does it sound?
Sounds very good inside the car but I haven't heard it from outside yet haha
So decided to just bite the bullet and order the Supertec R35 Brake adapters so they will be ready to be installed on the car after my next track day in June.
Seriously the quality of these things is insane and they are so light yet solid!
18236724_1360701314016290_366622205_o.jp
18253770_1360708987348856_576199854_n.jp
Also received this special box :D
I've already got the Ikeya Formula front camber arms (-10mm version) and I needed the lower control arms to complete the front suspension setup to adjust neg camber and caster to my liking and ensure my new wheels fit properly!
Also picked up new inner and outer ball joints as the current ones are worn and torn.
18493273_10155458721015572_1905962739_o.
18493269_10155458721025572_106193545_o.j
nengun-0634-01-ikeyaformula-roll_center_
And I figured my current headlights are pretty crap so I got these LED's which a friend has proven work really well..
18493476_10155458722040572_1978311073_o.
  • Like 1
i love my LED globes.
you get allot of the high horse, led bad light, blinding, hotspots washout, spewing all sorts of youtube based statsy ada yada. but they work so well, and the stock lights are so dangerouse
  • Like 1
With the stockies, I honestly can't see shit all and I want to be able to avoid all pot holes without needing the reflexes of a fox on speed.
@deongster runs them and he's very happy with them.
  • Like 1
So I fitted one side to show the difference but I bought the wrong fitment for my car. The later models have H1 where the earlier ones are H3.
But you get the idea for what difference it will make.
Ikeya Formula Front Lower Control Arms are now fitted and functioning beautifully!
Now my front suspension setup is complete and no more purchases are needed, I just need to replace the couple of chinese rear arms with Ikeya Formula stuff and get the rear Ikeya LCA's aswell to complete the whole setup!
18575897_10155474910480572_1977241886_o.
18575953_10155474910440572_1997723181_o.
  • Like 2
Yeah i run them with both my high and low beams... they make a world of difference - starts up instantly - unlike HiD's
i also have the mod - where if you switch on the high beam the low beam stays on... so i get massive amount of light... doesnt blind anyone
  • Like 1
Night time, find a while wall, level ground, take car back 7m, set your camera to 50 ISO, take pictures (one halogen one LED).
Here's a "3,000 lm/30W" LED vs. H11
Car was ~5m from the wall.
Not to shit on your parade, but I haven't seen a "good" LED bulb.
R32 projectors are shit house, best to get rid of them instead of trying to overdrive them with HIDs or have a scattered LED. Retrofit!
Remember, bright foreground != good lighting, unless you like to only see what's in front of your bumper.
Oh and the F3 Fastbright ballasts in my GT-R warms up Philips 85122 bulbs as quick (if not quicker) as my OEM Subaru Denso slim ones ;). $50 HID kit will always be shit compared to "proper" ones.
I also have relays/wires for the headlights ("anti-flasher" setup), lows operate independently to highs. If lows are on, they don't turn off when I high beam. If lows are off, they don't turn on when I high beam.
If you're so hell bent on LEDs, you can always put these in:
Koito LED lows from Japan.
  • Like 1
  • 3 weeks later...
  • 1 month later...
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
