Hi All,
I installed a bigger radiator a few weeks ago in my R33 GTST because it was getting warm on the wet pan and I intend on going on a few track days. At the same time I put in a new genuine thermostat just as a precaution.
Since this has been done the car doesn't get anywhere near operating temperature (roughly 80 degrees) i.e. sits at 45-55 most of the time and gets to 70 on hot days. I just wanted confirmation that this is safe/normal/OK?
I spent some time looking for similar threads where someone upgraded the radiator and had low temps but didn't turn up anything helpful.
Thanks!
Edit: Forgot to mention that I'm getting these numbers off an aftermarket gauge using the GKTECH upper radiator adapter thingo. Factory gauge sits at 1/4 - 1/3 when I see 45-55 on the aftermarket gauge
Edited by kingtube69
Have you checked that the thermostat is working correctly by say letting the motor idle and feeling the hose to see when it opens? In fact at those temps (if correct) the thermostat should not open. I would be inclined to pull it out and see if it is stuck open. Or first get another view of your water temps by say putting a thermometer in the radiator filler or using a laser gun type thermometer.
Running that cold is not ideal.
  • Like 2
I'll run it today and check what the temps are like on the hoses - What am I looking for when checking the hoses exactly?
Get a new thermostat, they're so cheap any how... also could be an air pocket too
I'll grab a new one from Kudos in the coming days - I let it run for ages and ages and ages to bleed it so I thought I got it all out but maybe you're right.
Is there some special technique to getting it all bled properly? I have just been filling a cut bottle past the engine (sealed in the filler neck) and letting it run that way - Tried cracking the bleed valve and it didn't seem very effective. I have a hard time doing it at my house unfortunately so I normally have to go to a park or petrol station because my neighbours complain that it's too loud
Put your old thermostat back in and see what happens.
Didn't keep it unfortunately :(
to bleed my system i usually jack the car up pretty high eg so i can get under the car, then put a bottle in the neck and run the car.
no a hundred percent sure its necessary but i also have the heater fan full and hot.
Edited by MatthewT85
I wrap a couple of rags around the bleed valve and crack it open and closed a few times. The first time I tend to leave it open until I get flow, then its just open till it dribbles then off. Its not that hard. On a slope [on jack or ramps] would create cavities and not bleed properly I'd reckon [but don't know], I do mine on all four wheels.
I tried the coke bottle trick once but it didn't make any difference for me, just added another complexity I didn't need so haven't used it since.
If you start it up from cold and let it idle you just feel the top hose and when the thermostat opens it will suddenly get hotter. Of course this will not be the case if your thermostat is stuck open. In this case it will just slowly get warmer.
If your bleed valve does not work clean it out until it does work. Where exactly is you temp sensor for your aftermarket gauge? I cut the top hose in half and put an adapter in there.
  • Like 1
Those temps are very low.
Are you sure your temp sender is reading correctly?
Is it earthed properly etc?
Post a photo of the setup.
Its odd that both would read low (stock and aftermarket) I'll check the earth just in case
http://www.gktech.com/index.php/r33-silicone-radiator-hose-with-water-temp-fitting.html
This is what I'm using - The temps were always fine on the gauge till I went bigger radiator from what I remember
I normally do this with the neck and tape to seal it, never tried jacking it up though
I'll give this a try tonight (take it to the servo near my house) I'll let you know how it goes when I try it
The temp sensor is in the top hose (http://www.gktech.com/index.php/r33-silicone-radiator-hose-with-water-temp-fitting.html) last time I checked the hose it was a progressive warm up. I also don't recall the lower hose getting very hot but I'll double check
I'm possibly being a little over dramatic about this all maybe too cautious.
I took it down the road, cracked the bleeder and no air came out only coolant which I guess is a positive. Heater is still very hot (in the past if it had pockets it was cold and not hot). The top and bottom hoses eventually were hot but not so hot that I would burn my hands by holding them. Temp gauge also read 60 after a short drive home (1 minute max). Is this still something I should be worried about?
If it matters I also have a nismo radiator cap.
^^^what he said. Pull the thermostat out and if it's stuck open it's obviously dodgy. I hope it's not one of those Nismo low temp thermostats. If so bin it and get a stock one. The Nismo radiator cap "shouldn't" be a problem.
also make sure the little jiggly pin is pointing upwards, i.e. highest point in the housing.. if it is in the wrong way you'll have massive air pockets before the thermostat opens
I think the genuine part may have changed somewhere along the line. I tried a tridon one and a nismo one and then an OEM r34 one from kudos, and they all open at about 60C and thats pretty much my water temp.... Across 3 gauges.
Bit of an update on this - On the warmer days it gets close to 80 degrees but on cold days and nights it sits around 60. Plugged the laptop into the ECU today and it was reading out 72 degrees but the gauges were saying it was cooler than that (the aftermarket and stock). Is the temp difference to be expected on cold/hot days?
I'll get a new thermostat this week but I'm a bit annoyed if it's a dud because it's still new. I'll also test the old one anyway.
Jiggle pin is definitely at the top as per FSM (read it prior to changing it out)
Is it worth getting a new thermostat housing while I'm there as I've been seeing people talking about how fragile they are?
Thanks for your help all!
  • 1 month later...
Hi All,
Found the problem recently
DB92CE77-07C4-4876-8B52-8D7FBDD10CD4_zps
This happened because its difficult to put the housing on without bumping the thermostat out of the block (gasket maker grabs it and moves it) so I made up some studs and tried again
Thanks again for the help!
  • Like 2
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
